Logitch and HTPC
  • ice cube
    • Jan 2015
    • 24
    Logitch and HTPC
    Hi. How can I connect my PC with a logitch remote control... I have Logitech Harmony Ultimate Home Touch Screen Remote.
  • Kevin P
    • 10812
    Get a Media Center remote with USB IR receiver, such as this one: http://www.newegg.com/Product/Produc...9SIA1HE0S20594
    Then program your Logitech to send the codes to your HTPC.
    I don't know if you can buy the IR receiver by itself or not, they all seem to come with the remote. But it's always good to have a spare anyway.
      You can do it over IP as well if you have a way of sending signals over the network.
        I just set up a Flirc to control a PS4. Can control anything that can accept a USB keyboard input.
        Flirc makes cool things for your media center, as well as supporting unique creative ideas. Raspberry Pi cases that absorb heat without any need for a fan. The Flirc USB that allows you to control any USB device with any remote you pair it with. The Jeff Probe for in house debugging. And more to come!
        • TimbaLand
          • Aug 2013
          • 139
          I can control mine via IP using the Kodi app but I would like to find out if it's possible to add IP functionality on the Logitech hub so that I don't switch between apps to control my professor and the HTPC. Is it possible to program IP control through the harmony hub?
