Dvd reader/burner on Netbook?
  • madmac
    • Aug 2010
    • 3122
    Does anyone know if there would be any issues connecting an external Dvd writer/reader to a Netbook via USB connection?. Will it work ok?.
    It's either that or buy a new Notebook (More expensive option!!)
    Dan Madden :T
  • stuofsci02
    • 1241
    Should be fine.. Make sure you get one with an external AC adapter though..
    Main System:
    B&W 801D
    Emotiva USP-1 Pre-Amp
    Chord SPM-650 Stereo Amp
    Oppo BDP-105
    Squeezebox Touch
    Second System:
    B&W CM7
    Emotiva UMC-1
    Emotiva UPA-2
    Oppo BDP-83SE
    Grant Fidelity DAC-09
    • madmac
      • Aug 2010
      • 3122
      May I ask why it would need an external adapter and not run off the USB power feed??.
      Dan Madden :T
        Because they don't have a lot of power coming into them, I think the power brick on those things are only like 40 or 50 watts max.
        • madmac
          • Aug 2010
          • 3122
          Ok got it!!. Thanks!!
          Dan Madden :T
          • madmac
            Funny story with portable DVD burner!
            by madmac
            I have a Netbook and bought this Samsung portable DVD burner. I had nothing but trouble and frustration with it at the beginning.
            then...my 13 year old daughter comes over...... literally touches it and the Netbook and POOF!!!. It works!!. What is it with kids nowadays !!! :rofl:...
            13 October 2012, 15:18 Saturday
          • BWLover
            External sound from PC
            by BWLover
            i have a laptop that i want to connect to my stereo. when i used a Y adapter (3.5mm to RCA) i get a hiss in the background from the crappy sound card in my laptop. what would be a good cheap external sound card. all i need is RCA (red and white) outputs. i have a Toshiba qosmio g30. I think i would...
            03 October 2009, 19:58 Saturday
            CD burner problem
            by Andrew Pratt
            I have a HP 9100 8X CDRW burner on my Win2K machine running EZCD4 using an overclocked celeon CPU (running at 1000hz) with ATA100 7200 RPM quantum HHD. My problem is that even if I am copying files from the hard drive to the burner it won't burn faster then 4X w/o getting a buffer under run. I'm wondering...
            27 April 2001, 15:32 Friday
          • TommyV
            Using a USB to Serial adapter for FW update w/ Vista
            by TommyV
            OK I would like to hear from people who have successfully used a USB to serial adapter/converter cable to update the firmware on their 10 or 15 series processor or AVR. I want to be able to use my laptop to do this update which is Vista 64bit. I am trying to update my RSP-1069
            hifiguy...
            13 June 2009, 04:10 Saturday
          • SteveHauck
            Trouble with vesa to component adapter
            by SteveHauck
            I have been using an InFocus X1 for a few weeks with great results. Today I purchased a new progressive scan dvd player and the VESA to component adapter. For some reason I am gettng not pictutre thru the adapter. I've checked out the component video cable and it is fine. I feel like there is something...
            02 June 2005, 19:56 Thursday
