Harmony 880 update problem
  • howzitwerk
    • 11
    I have had a Harmony 880 for quite a while, worked great for a long time then all of a sudden it won't take updates, lists some kind of Java error. I updated the firmware, no difference. Anyone had anything like that?
  • bmowis
    • Oct 2006
    • 45
    Can you tell me what the "Some Kind of Java Error" is?
    • howzitwerk
      • 11
      well wouldn't you know, it's just like taking your car to a mechanic. I haven't tried it in a while, I just started it up which got the latest Logitech app version, and it now seems to work. Last time I tried a while ago, I updated both the software and the remote firmware, and was getting the error with every computer I tried, Mac or Windows.
      Well, thanks for prompting me to try again, it may be ok now! I have to change some activities programming for new gear, so there will be more update attempts, but this is the first time in a long time any update worked. It is a new version of the Logitech SW so they may have fixed something there.
