Harmony 880 rattling noise
  • Wick
    • 39
    There is a very slight rattling noise when I tilt the remote. Does anyone else have this noise? Im not sure if its the sensor that lets it know when its tilted or a defect. I will return it for another if its a defected one.
    Paul
  • ekkoville
    • 392
    I have the same thing Paul. It is so slight I need to put my ear up to it though. I think you may be right about the sensor. It sounds like a very very slight scratching when I tilt lengthwise or side to side.
    ____________________
    Erik
    Just another case of the man trying to keep us down! :B
    • Wick
      • 39
      Yeah, its so slightly that you dont notice unless holding it up to your ear. And the remote works perfectly, so its prob not a big deal. Just wanted to make sure since the thing is so expensive.
      Paul
        • 1537
        Mine does the same thing! :lol:
        Must be the sensor inside to turn it on?
        B&W
        • Trevor Schell
          • 10935
          Mine rattles too.
          Only, I never noticed it until I read this.
          I had to try it for myself and sure enough,
          a slight rattle can be heard.
          It must be the motion sensor that
          automatically turns on the LCD when
          movement is detected.
          Trevor
          XBOX 360 CARD
          • Audiophiliac
            • 346
            Correct. It is the "pickup" sensor. No worries.
            • peterS
              • 1038
              yes it is a tilt sensor
