I am having a lot of difficulty getting a usable video signal to my television from my newly built HTPC, and was hoping someone with some more expertise could give me some advice.
Here is my setup:
TV: Sony KV-32XBR400 (supports 480i, 480p. 1080i through 2 component video inputs)
HTPC:
MCE 2005 (with all updates)
XfX Nvidia 6600GT video card (dual DVI + S-video - latest Nvidia MCE driver)
Hauppage WinTV-PVR-500 tuner/video capture card
Silverstone LC-10 case
Abit AV8
1024 MB DDR
200GB IDE HDD
NEC DVD-RW
I am using a DVI-VGA adapter on one of the DVI ports on the video card. From that I have a VGA cable that goes to an Audio Authority VGA-Component Video hi def video transcoder. From the transcoder I have component video cables to one of the two component video inputs of my television.
When powered on, the display is mis-colored and garbled. It is garbled during the entire boot process, including Windows. I have attached an s-video cable to the s-video output of the video card, and attached it to another input on the TV. From this I can get a signal. I have loaded Powerstrip and have attempted to use some of the pre-defined timings for the various HDTV resolutions, with no success.
I can view the VGA signal through the DVI-VGA adapter on another monitor with no trouble.
I can view 1080i HDTV on this TV with my set top HD receiver without difficulty (using the same cables and component inputs). I also have a progressive scan DVD player using component cables that works perfectly as well.
Any advice for this HTPC novice?
Mike
Here is my setup:
HTPC:
Abit AV8
1024 MB DDR
200GB IDE HDD
NEC DVD-RW
Mike
