cables for hdtv
  • docted
    • Apr 2004
    • 4
    cables for hdtv
    I am awaiting a new Toshiba 51hx93. It will be connected to hd cable.
    What other cables are recommended for hook-up to an Onchyo DVD, a laser disc (Yes!) player, a VHS and a connect between the hdtv cable box and the TV.
    I have considerable high end hi-fi equipment and a multitude of older cables including s-video, s-vhs, etc.
    Thanks. I am a newbie to this fantastic site.
    Ted
  • Bam!
    • Jan 2004
    • 2458
    docted!
    From what I understand....unless your Onkyo doesn' t have DVi. (highly unlikely it does...actually I know it doesn' t)....it won' t change much....however if you can go component go.....for the VHS....doesn' t really matter either way.....
    Hope this helps!
    Got a nice rack to show me ?
    • Kevin P
      • 10812
      Different connection types yield different amounts of video quality. From best to worst, those connection types are: DVI, RGB, Component (HD), Component (480p), Component (480i), S-Video, Composite, and way at the bottom, RF Coax.
      For HDTV, you have to use component video, or DVI. The other connections aren't compatible with HDTV signals. RGB is only available on projectors, and generally not on consumer RPTVs.
      For DVD, use component if you have a second set of component inputs on your TV. Otherwise, use S-video. If you have a progressive scan DVD player (480p), you have to use component to gain the benefits of 480p.
      Laserdisc is a native composite format. If your deck has an S-video output, try both composite and S-video to see which looks better on your TV. If your TV has a better comb filter than your LD player (which it probably will since you're getting a new Toshiba), composite will look better for LD.
      For regular VHS, composite is probably the best you're going to get. If you have a S-VHS deck, S-video will give you some improvement.
        Twin Moderator Emeritus
        • 16706
        Ideally you want to connect each component with it's most superior output. Unfortunately not all equipment has DVI or Component outputs. Basically the order you want to use (based on availability) is DVI, then Component(Colour Stream), S-video, Composite(RCA) and finally coaxial cable. (There are a couple of other formats that tend to be in more "professional" gear like RGB and RGB+HV that you shouldn't have to worry about) Of course you'll also want to use quality cables. If you're looking at upgrading to some quality cables check out one of our forum sponsors Cat Cables. They make awesome quality cables at reasonable prices with even better customer service.
        • docted
          • Apr 2004
          • 4
          hdtv cables
          Thanks for your replies.
          Ted
          • Bing Fung
            • 6523
            Hi, I'm using the Shaw Motorola DCT 6200 High Definition cable box and a Toshiba 51HX93.
            Currently I'm using a Belkin DVI cord to connect the Cable box to the TV. In comparision tests the DVI is slightly cleaner than the Component input.
            I'm using Cat Cables Tigress Component cords from my DVD to TV. They are beautifully made, and send a very pure signal.
            My Denon receiver is connected to the TV with a AR S-Video cord. It does the job for the receiver's Onscreen Menu.
            My Xbox is currently connected with the standard Microsoft cheap moulded cords (S-Video, Toslink Optical) Soon it will be replaced with a set of Moster Cable XGL400 Component cords.
            Like Jason stated have a look at the Cat Cables lineup
            Bing
            • Frank
              RDC-7 and HDTV..Great!
              by Frank
              I finally purchased extra Canare component cables and have run my DVD and Hughes E86 thru the RDC-7. Excellent results. To bad the on screen display does not work thru the component output. HDTV looks better going thru the RDC than direct to the TV, however, this may be the result of the new cable rather...
              12 October 2002, 09:04 Saturday
              CATCables is now in the digital interconnect and component/composite video biz!
              by Lex
              Gentlemen, start your engines. Your Dolby Digital and DTS engines that is. Tonight, I just opened the first of my new CVDT (Custom Video and Digital Transmission) branch, with the introduction of Twisted Kitties and Soft Kitties Silver Laced Digital Interconnects. I dare you to compare quality and...
              07 July 2001, 01:46 Saturday
            • motorsportnut
              1068 and transcoding issue with DVL-91
              by motorsportnut
              Hi All,
              I just upgraded to a 1068 a while back and had an issue that I hoped someone in the forum could answer. I have a Pioneer DVL-91 combo DVD/LD player which I wanted to connect via component video only. When I play a DVD everything is OK. When I play a LaserDisc the DVL-91 shuts off the...
              12 April 2004, 15:38 Monday
            • Kees
              1098 conversion composite to component
              by Kees
              I'm getting my 1098 tomorrow, but downloaded the manual from Rotel's website. I have a question on the conversion from composite or SVideo to Component. I hope one of you can help me!
              My ideal setup is:
              VIDEO 1: S-VHS player (with S-video cable)
              VIDEO 2: Hi-8 player (with...
              08 September 2003, 14:16 Monday
            • cisco
              What DVD player should I get for this HDTV?
              by cisco
              I am about to buy a Zenith 40" 16:9 HD-Ready Rear-Projection TV with DVI Input, 480p/1080i progressive scan, Model R40W46. It has DVI, Component, S-Video, and Composite inputs. I will be using the TV mostly for DVD movies.
              Is it worth getting a DVD player with upconversion? How...
              25 December 2004, 18:47 Saturday
