Front Projector
  • chuckaroo
    • Apr 2004
    • 26
    Front Projector
    Hey Guys,
    Thanks for letting me take part in the forum. I've been retired for a number of years (71, Air Force) and I'm trying to put together a home theater. I have a 10X14 foot room with no windows and a sony STR-DE995 Receiver. Also I have a Infinity BU-2 Subwoofer and the minuette speaker system front,center and surround. The sony is a 7.1 so I purchased 2 more minuette's on ebay to complete it and have 4 rear speakers.
    Now my big dicision is" What is the best projector" in the price range of 1200.00 - 1700.00. I'm pushing 71 and I don't want to get taken.
    After reading this forum, I know I will get good advice.
    Many thanks
    Chuckaroo
    Chuckster
    Chuckster
  • Bam!
    • Jan 2004
    • 2458
    Hey Chuckaroo!
    It`s Bamaroo!
    hey why don`t you check out the thread right below this one one...The Infocus X1....is...right in your price range....and....it is a DLP!
    woo whoooo!
    I have it....and....I love it Truly!
    Take care !
    Bam!
    Got a nice rack to show me ?
    • George Bellefontaine
      • Jan 2001
      • 7636
      And if DLP gives you headaches or causes you to see color flashes( Rainbows) try out lcd. I believe the Sanyo HD2 falls in your budget range at USD. A few here own this PJ and love it. Plus it offers 1280 x 720 resolution which will be good if you will be watching high definition tv shows on your PJ. If you are only going to use it for dvds, Epson has a PJ with dvd resolution for $1200USD and may even street at much less.
      My Homepage!
      My Homepage!
      • chuckaroo
        • Apr 2004
        • 26
        Sure do appreciate all the good info. I have taken your advice and have checked out the X1, also I have been looking at the Sanyo Z2, what do ya think? Specks look great. Anybody out there have any info on this machine?
        Also I checked out this bright white screen with a gain of 1.0 to 1.3 on ebay. This stuff any good or does the ME paint put it down?
        Thanks a heap. You guys are a great help. Would appreciate your continued input.
        Chuckaroo
        Chuckster
        Chuckster
        • Bam!
          • Jan 2004
          • 2458
          Chuckaroo!
          Cjeck out the thread below my Trevor Schell...comparing the Matinee to the Z2...it pretty much sums it up....
          If you have the budget for the Matinee or Z2 I would take that over the X1 because the Z2/Matinee are in HD.....
          For the screen...I have a 0.8 gain screen because these projectors play very bright and I want the deepest blacks possible....Your room has a lot to do with it to....
          Take care...keep us in touch!
          Bam!
          • chuckaroo
            • Apr 2004
            • 26
            Thanks BAM
            I'm sure it will be one or the other. I hear the Matinee has a better warranty so I lean that way a little more.
            Thanks a lot for the great info and I'll let you know how it all works out and now.........back to doing some more dry walling.
            Chuckster
            Chuckster
            • Sonnie Parker
              • Jan 2002
              • 2876
              Hey Chuckster... glad to have another southeasterner aboard... welcome! I'm only about an hour from Florida.
              You may have a hard time finding a 2HD for less than about $2k right now but the Z2 (same machine) is floating around in the $1700-$1800 range. I'd jump on it. For HD or widescreen material it's gonna be hard to beat IMO. I tried to find the link but couldn't... I know I read somewhere that the Z2 was at $1749 or $1789. You may have to dig really deep to find it but I know it's out there somewhere. When I have more time maybe I can find it for ya. Most of what I've found just on a quick look was $1899-$1999.
              Even the 1HD and Z1 (same machines one step down from the 2HD and Z2)) are nice... a couple of guys here in the forum own those and have been very pleased with them. Those can be had in $1100-$1200 range.
              SONNIE
              Cedar Creek Cinema
              DVD Collection
              BFD Comprehensive Setup Guide
              • Brandon B
                • Jun 2001
                • 2189
                The Z1/1HD are the previous year's model. The resolution is substantially less (960 x 540), although this is the "1/4 HD" resolution that scales nicely with HD sources, so it is not a completely negative factor compared to the Z2.
                More importantly (maybe) is the Z1 does not have a DVI port, which the Z2 does.
                Another good candidate is a very-soon-to-be-released infocus HT PJ in this price range, read about it here. I would certainly consider it, as InFocus' units are pretty much competitve values across their product line.
                BB
                • Dean McManis
                  • May 2003
                  • 762
                  I'd also recommend squeezing the budget a bit to get into a Z2. HDTV is astonishing to look at, with a 1280 X 720P projector, and it's quite likely that HD DVDs will be available within the next two years, so spending a couple hundred dollars today would have a good reward a couple years from now.
                  And the regular picture of the Z2 is visibly better than the Z1 even with NTSC material.
                  -Dean.
                  • Legairre
                    • Jan 2002
                    • 231
                    I've recently paired my Z2 with a Momitsu 720p/1080i DVI DVD player and the PQ is stunning. the Z2 really shines with a quality signal. If you see a Z2 with HD or a DVI player you'll have to have someone hold you back from buying it.
                    "What do you mean it's too loud? My ears aren't even bleeding yet!"
                    Radden Home Theater
                    • Shane Martin
                      16x9 720P DLP HD2+ for $3,299 MSRP
                      by Shane Martin
                      Benq has one out now.. Seems rather amazing..
                      BenQ Expands Line of Award-Winning Home Theater Digital Projectors
                      PE7700 Features Latest HD2+ DMD Chipset from Texas Instruments, 1000 Lumens,
                      a 2500:1 Contrast Ratio and 6-Segment Color Wheel for High Performance ...
                      22 April 2005, 10:28 Friday
                    • Ovation
                      How NOT to sell a projector
                      by Ovation
                      Yesterday I was in a local Best Buy for a bit while running some errands. I went in to take a look at some DLP RPTVs to see if the rainbow effect that I found so objectionable on my wife's office projector was a problem for me with ANY DLP device or just that projector. Well, after looking at 5 different...
                      08 April 2007, 09:17 Sunday
                    • Dean McManis
                      1080p DLP front projectors announced
                      by Dean McManis
                      Of course this was inevitable after the rear projection DLP 1080p displays were announced. :T But the BIG question will be the FPTV unit pricing.
                      Of course these new DLP projectors don't actually...
                      09 September 2005, 01:22 Friday
                    • NHT
                      Front Projector or Rear Projector
                      by NHT
                      hello again fellas. Ive been shopping around for a new tv for the last 2 months and cannot come to a decision. Choices choices! There are so many to choose from that Im going zonkers and just want to pull all my hair out! To top it all off, my wife and I went to a Home Show today and there was a home...
                      18 April 2004, 22:57 Sunday
                    • NHT
                      by NHT
                      18 April 2004, 23:32 Sunday
