Calibrating Sony SXRD
  • avrtRick
    • 63
    G'day to you,
    Does anyone know the best and easiest way to calibrate these sets for contrast and brightness.
    I find this the hardest thing to do as all my sources go through DVDO's VP50. 8O
    where should I start?
    Should I buy avia disc or something? :W
    I know it is a juggling act,but still the hardest thing.
    I did think of getting my AVspecialist to do this but at $600(could be well spent though)I thought I'l look for some help first.
    tv is Sony KDS60R2000 and as stated everything is processed by the VP50.
    Anyone that has any experience with both of these products,do you have any insight to pass on.
    Thanks in advance :T
  • maseline_98
    • 317
    I have the kds-60a2000....you should try the avs-forum if you don't wish to purchase a avia disc. $600 is a little absurd, but there are a ton of settings...good luck
    Sony kds-60a2000\Panasonic BD-55k\XBOX 360 Premium(20gig)Slingbox\Xbox(flashed) running XBMC
    Emotiva UMC-1\Emotiva XPA-5\Klipsch (2)RF-7s with DeanG xover upgrade, RC-7 with DeanG xover upgrade, (2)RS-7s\SVS 20-39PC+
    _____________________________
    “Insanity: doing the same thing over and over again and expecting different results.” - Einstein
    • avrtRick
      • 63
      I have posted there also.
      Now Im just waiting
      Nearly all pricing here in Oz are absurd,but Im willing if I have to.
      Plus I have quite a few things to calibrate
      • avrtRick
        • 63
          Twin Moderator Emeritus
          • 16706
          Either AVIA or DVE is a good starting point for the DIY'er and should help get you most of the way there for little money and a bit of work :T
          If you want to get every last ounce of performance out of your set, the best route would be to have it calibrated by an ISF certified tech:
          And yes, that $600 does seem a bit steep unless they're doing every RPTV tweak known to man including lining the internal cabinet maybe...?
            Avia Pro DVD (and Digital Video Essentials)
            For those who don't know, new editions of Avia and Digital Essentials are about to be released for new technologies since the original editions. Both videos are useful reference items to use in learning about, setting up, and fully calibrating your system in both audio and video. I own both original...
            22 July 2003, 02:41 Tuesday
          • stjoenewt
            Calibration problem using AVIA
            by stjoenewt
            This last week I was calibrating my RSX-1055 and noticed a problem. I was using the AVIA disc in a Panasonic DVD player. The DVD player is connected via both optical into one of the digital inputs, and analog into the multi-channel inputs. I did this due to the fact that the player can play DVD-A recordings...
            15 October 2003, 11:49 Wednesday
          • RonK
            Calibrating Rotel 1068 with AVIA
            by RonK
            Going from a Denon 3802 to a Rotel 1068. The master volumes are different. The Denon went from -85 to 0 and I would set the master volume to 0 and calibrate with AVIA to 85db. The Rotel goes from 0 to 85 or 90. I'm not sure where I need to start from. 85 seems to loud, should I start at 65 or where?...
            31 May 2005, 10:06 Tuesday
          • ajpoe
            Calibrating your speakers
            by ajpoe
            I have kind of a unique question because I don't use a .1 sub. I have a powered sub on each of my front L & R and rear L & R so I have 4 full range channels for movies and 2 full range channels for music. I have my center set as small at 80 hz.
            I had my system calibrated based...
            21 February 2005, 15:42 Monday
            Got $20K? Get SXRD...
            Under the category of, "If you have to ask, it's too much".....
            Of course, it's sounds even worse in Yen, something like 2.4 million...
            Sony SXRD FPTV
            Display Panel : 0.78 SXRD Approximately 622 ten thousand pixels
            (2,073,600 pixel) x 3
            Lamp...
            14 June 2003, 10:44 Saturday
