will a vga to component cable allow me to use component cables or is another meathod needed potentially?
have on old epson power lite 730c with only vga input
by BentGreetings again, a friend bought a Epson LCD pj (the new 800 by 600 model), he is looking for the adapter plug that has component video in to allow him to use it for DVD's he seems to think that this plug should be in the neioghborhood of $100 CDN, this sounds outrageously expensive. Is there any product... -
by JerriI have an Xbox with a VGA (HD-15) adaptor. I understand the Xbox's widescreen 480p mode to use 640x480 anamorphically compressed video, similar to the 720x480 anamophically compressed video from a DVD player. I want to be able to connect the Xbox to a projector using the VGA adaptor and have it display...10 January 2005, 18:22 Monday -
by safaa426hello every one , i`m new here.
i just have a Q,
can i use vga splitter to split a component signal from dvd player using powered vga splitter.
the reason is i want to drive the sony tv and panasonic pj at same time,using a dvd component signal.
if this is possible...-
by P-DubI was wondering which would offer the best connection from a laptop to a projector. I can either use a S-Video or a VGA cable. The projector is a fairly new portable that supports 800x600. My gut says use the VGA cable.
Though the laptop doesn't support a component connection, but in... -
by Dean McManis"Epson's first 3LCD projector to take advantage of their new 0.74-inch HTPS panels already spotted in Mitsubishi and Sanyo projectors. The EMP-TW2000 starts with a trio of Epson-built, 0.74-inch, 1,920 x 1,080 C2FINE LCD panels with D7 process technology, 12-bit LCD driver, and updated OptiFocus... - Loading...
- No more items.
