Best Remote Control drop down 16:9 screen
  • kfr01
    • 83
    Any suggestions. I want my screen out from the wall so I can fit some room treatments behind it.
    Is this a horrible idea?
    Thanks!
    Karl
    My Chain: PC Audio (EAC + FLAC) --> USB --> PS Audio Digital Link III USB DAC --> Exodus XLR's -->
    Parasound Halo P3 --> Exodus XLR's --> Parasound HCA3500 --> Custom Exodus Audio 2641 Speakers
  • Audiophiliac
    • 346
    Stewart.
    Do you have a screen now? If you have a fixed screen and are happy with it, just space it off the wall. Or hang it from, the ceiling.
    • kfr01
      • 83
      Thanks for the reply. I do not have a screen now. I am building a new listening / HT room in the basement.
      Edit: Is fixed screen hanging or spaced off the preferred way to go? I just want some absorbtion behind the screen to help cure some length-wise room modes.
      Thanks!
      Karl
      • Audiophiliac
        • 346
        Fixed screen is less expensive by a good margin, and it would not be hard to space it off the wall enough to get some treatment behind it.
        Its a personal preference. If I had a dedicated theater only room, I would do a fixed screen. But it sounds like you have a multi-purpose listening/HT room, and you may not want the screen there all the time. Then get a motorized.
        I prefer Stewart screens. But you can find less expensive alternatives out there that still look good.
        • kfr01
          • 83
          Wow. Those Stewart are pricey.
          Carada Projection Screens seem to be a decent value. Has anyone tried to push them off the wall?
          Karl
          Karl
          • Preacherman
            • Jan 2004
            • 122
            DA-LITE
            Has worked well for me.
            The one I have.
            Bruce
            Individuality - Always remember that you are unique. Just like everyone else.
