possible antenna issue Mitsubishi 52525
  • xilpaxim
    • Oct 2004
    • 8
    So, the other day, my comcast cable channels all start showing up snowy. I can see the picture, but lots of snow on the screen. I have the cable directly plugged into the tv. They don't get the wb HD channel, so I went out and bought an over the air antenna for that channel. That antenna seems to have lost the ability to get any channels pretty much at all. So, has anyone heard of the antenna failing on this model. The cable guy came out and said that it was the wires going through the house, and we tried fixing half of it, but didn't have time for the rest. I can get one of the HD channels now and the snow is a little less dense, but I still have the problem. any suggestions?
    Twin Moderator Emeritus
    • 16706
    Could just need re-aiming, could be bad wiring, could be a bad antenna.... hard to say.
    Though on HD channels the pic should never go "snowy". Digital pictures break up but don't snow. That's an analog problem. What about the interconnects to the TV any interference on them possibly?
    • alstein
      Toshiba 57HX93 and Antenna connection
      by alstein
      HI
      I purchased a Radioshack UHF/VHF HDTV #15-1880 antenna, and initially connected it to the antenna 2 (input #7) of my Toshiba 57HX93 TV. When I went to setup to configure this input, no channels were found. have been unable to find anything at all in the Toshiba manual about this tuner and...
      25 April 2004, 08:30 Sunday
    • Sonnie Parker
      Local Digital Channels Info
      by Sonnie Parker
      Some of you may already be aware of this site as I have known about it for a while now myself, but I thought I'd mention it again anyway.
      antennaweb.org
      Enter your street address and see the analog and digital channels within antenna distance of your home. Not only...
      27 September 2003, 02:28 Saturday
      HDTV Antenna Web
      by Lex
      Guys, I happened across this link, and was quite surprised to find that I could actually receive 2 HDTV providing channels with a medium size antenna. There are no local stations sending an HD signal. It is possible Icould be blocked out by a ridge, dunno for sure. But it actually could work.
      28 March 2002, 10:36 Thursday
    • ssv
      Direct TV dish as HD OTA antenna?
      by ssv
      I JUST got my 42" plasma flat panel HD tv (Magnavox 42FM230A), mounted on the wall, looks great with DVDs. According to Antennaweb.org I'm about 21 miles from my local HD stations transmitters. The previous owners of this house had a DirectTV dish and LEFT it mounted on...
      25 March 2006, 17:43 Saturday
    • tkporcel
      Mitsubishi WD-62525 issues
      by tkporcel
      Hi All,
      I just purchased a Mitsubishi WD-62525. I am having some problems with sound and picture. On some channels I get a static noise, this maybe due to a crappy power strip I am going to investigate this further. My main issues is the bad picture in cable. I have basic cable and...
      21 March 2007, 16:21 Wednesday
