my TV just went out today. It is a Pioneer SD-643HD5 (rear projection?). Power will turn on but it stays on stand by. I would really appreciate anybodies help to fix this. Thanks
Help, Pioneer SD-643HD5 won't turn on
Doesn't sound like anything we can fix from here sadly... Is it still under warranty? If so, contact your dealer and/or manufacturer for warranty service. Most places should be able to send someone out to look at it.
If it's out of warranty you should be able to find out from Pioneer's web page (or phone customer service) a local authorized repair centre
Jason- Bottom
by selfilmHello Everyone,
I have a Pioneer Elite BDP-05FD Blu Ray player and the Blu-Ray portion of it is not working. It still plays audio CDs and regular DVDs. The reason why I love this machine is that it has RCA audio outs for my system so I know I am getting the best possible audio (meaning I don't...-
Channel: Blu-Ray®
by Jeremy77I have a Pioneer Elite Pro-610hd hd-crt-rptv and recently I noticed horizontal lines going through the picture. The lines are the most defined any time the tv has a solid color or plain white background on the program material be it dvd or hdtv. It is hard to describe this in words, but it looks like... -
by P-Dub
I thought I would write a quick review of my exeprience with this unit. By no means is will this cover everything, but if there are any questions on how the unit functions, please don't hesitate to post here and I will try to find out.
My main reason for...-
by donkJust bought a 1066/1075 (not even hooked up yet) and came across the "double bass" issue with the multi-inputs here.
Sent Rotel tech-support an e-mail about the resistor cut fix and rec'd e-mail indicating that the "double bass concern is erroneous" and that there...-
Channel: Club Rotel
by facedoctorHi, I purchased a 50 inch pioneer elite plasma television, an a/v receiver vsx-74txvi and the wireless headphones SE-DIR800C. I also purchased a digital optical cable.
I am unable to get the headphones to work through the optical output of the receiver.
I am sure that I am doing something...-
- Loading...
- No more items.
