Hello All!, Anyone know of a projector mount that is retractable? I am looking for one that would raise my projector back into the ceiling after I was done with it. I have found one, but it is quite pricey$$$$$$$. It was around $2500 :E
Projector mount
I've seen them advertised off and on in home theater mags. But they were all pretty damn expensive.- Bottom
You're already looking at the "cheap" ones. That kind of automated functionality is very expensive.
I saw a "pre-owned" elevator mechanism at a dealer about a year ago that they had taken back from a customer who had decided not to use it in a custom installation they were doing for them, (reportedly preferring fixed mount after the novelty of the disappearing projector wore off) and the store was asking almost $2,500 for it used.
Burke
What you DON'T say may be held against you...- Bottom
One thing that you might research is building an extending mount out of something that is far less expensive. These items have a HUGE home theater "tax" added to their pricing because the market is so small. But if you creatively search around for a device that is far more common that does raising and lowereing, you might be able to construct something for a fraction of the price. :T
Maybe built from an electronic scissors jack, or automatic door opener.
One point is that because the current digital front projectors are so lightweight, the load/support capability only has to be a few pounds, so it doesn't have to be super heavy duty as the old ones were to support a 200lb CRT front projector. 8O- Bottom
Thanks Dean, that is a really cool product, I am glad you put that link up,my brother-in-law had a stroke and is now confined to a wheelchair. He is having a house built that better suits his needs, and those should come in handy for him. Plus they may work for my application.Robert P. 8)
AKA "Soundgravy"
by theSvenThe time had finally come to upgrade the projector in the theater to 4K. I have a friend that uses JVC in the area and having seen many movies on his JVC I loved the vivid colors and the blacks. I was using a second hand Sony VPL-VW50 (White Pearl) since 2013 and it did great for 1080P. The only thing... -
by markyboy56hi
can the benq 2050a projector
do 180 to 200 inches at 11feet throw distance that is the depth of my room and still have a fantastic picture without altering the brightness light ambience
is there anthing that can be altered to do this
thanks kindly...04 February 2019, 18:03 Monday -
by LexSpeaking of Elements, the 3rd movie I watched "OOB" out of box, was drum role..... Blu Ray 5th Element. It's always a crowd pleaser, and we know it's a pretty good older production, that holds its own as a nice watch on better TVs, be they LCD, flat panel, old Plasma 1080P, or DLP or LASER,... -
by Andrew PrattAs I promised to some awhile back here's my DIY projector mount.
Initially I built a mount from an old camera tripod which was great becasuse it allowed me to move the mount up and down easily as well as some tilt adjustments.... -
by Chris DOkay, I'm at the end of my very long home theater project, and am finally going to buy a projector. Help me decide which one to go with!
I've been looking for a projector I can get under $2500 end price that can show 720p minimum resolution pictures on a 16:9 format image. Here's what... - Loading...
- No more items.
