If you have digital tv and a progressive scan dvd player will it automatically go into the progressive scan mode while playing a movie or not?? thanx howie 8)
Dvd Help!
Depending on the player you switch it to progressive mode either via a button on the remote, a menu setting, or a switch on the back of the player. Once it's set to progressive, it normally stays in progressive unless you switch it back.
If you're referring to 2:3 or 3:2 pulldown, most players handle this automatically, though you can usually override it in the menus.- Bottom
by McLovinG'day,
I am having an issue with my RSP-1068 and progressive scan inputs.
I have three video input devices hooked up to the 1068: a set-top box, a DVD player, and an Xbox (on V1, V2, and V3 inputs respectively). The 1068 is then connected to my TV (a Sony LCD). All inputs...-
Channel: Club Rotel
by dennis123Hello,
I bought a Rotel system a couple of weeks ago and I’m very happy with it.
For all of my questions I searched the forum, but now I have a problem and I can’t find the solution on the forum…
Last week I bought cables to link my dvd-player 1060...-
Channel: Club Rotel
by junior77blueSo, if my hitachi TV upcoverts all my signals into 1080i, what's the purpose of having a progressive scan DVD player?
Wouldn't it make more sense to 'feed' the TV with a raw signal as opposed to feeding it the progressive scan signal, and then having the TV upsample that once again....-
by HenkThe RSP 1098 TFT screen displays no video unless a usable signal is passed through the composite video connection. However, as pointed out in the RSP 1098 manual not all dvd players, set in progressive mode, output a usable composite video signal. This is true also for dvd players that play dvd audio....-
Channel: Club Rotel
by P-DubFrom what I know, if I don't have a TV capable of receiving a progressive scan signal, a progressive scan DVD player is a waste of money.
However, with the prices coming down, should it be a consideration? I'm thinking about the cost of the Tosh 3750, which I've seen for C$350 and the... - Loading...
- No more items.
