Missing threads?
  • Lectoid
    • Jan 2007
    • 53
    Missing threads?
    I noticed the number of threads is a lot higher than the actual amount of threads. Did something happen? I am a new user here and was hoping to do a lot of reading. For instance, the B&W forum only goes back to the beginning of December of 06. I looked and didn't see any mention of data loss.
    Thanks.
  • Kevin D
    • 4601
    Under the last message there's an option menu. It defauts to messages in the last month. Change that to how far back you want to go.
    Kevin D.
    • Kevin P
      • 10812
      You can also go into User CP, Edit Options, under Thread Display Options, you can change the Default Thread Age Cut-Off for your profile to whatever you like. The default is 1 month.
      • Parrot Head
        1066 Default Setting
        by Parrot Head
        I need to ask what may be a dumb question about the 1066’s Default Setup. I’ve been adjusting the rear channel settings via the remote to approx. +7dB. I find this (although it may be a bit exaggerated) improves the surround experience when listening to basic cable.
        My problem...
        07 May 2003, 08:33 Wednesday
      • DER
        RSP 1068 - Setting User Default
        by DER
        Please Help. I have been unable to reset the User Default so that when I turn on my ipod (going into Video 5) the default mode is stereo. ...
        13 September 2008, 20:50 Saturday
      • Britchie
        Changing default speaker levels on 1098?
        by Britchie
        Whenever I turn on my 1098 the rear L and rear R is +2. All of the other speakers are 0. I tried many diffent ways in the user default setting to change them but to no avail. It is an inconvienience to have to manually balance the levels each time I power on the system. There...
        03 September 2004, 20:31 Friday
      • Kevin P
        Where'd the sticky threads go?
        by Kevin P
        The Mission Possible DIY "sticky" threads have a new home!
        They are now in the Missions Accomplished! sub-forum.
        This helps de-clutter the DIY forum, making it easier to find new posts/threads there. When a thread is determined to be suitable for a sticky, ThomasW...
        12 June 2006, 16:07 Monday
      • emf
        RSX-1056 surround default
        by emf
        This issue came up a month or so ago but never received much discussion. Mods, please feel free to move or otherwise treat as necessary.
        I've noticed that the surround default from DD2.0 on my RSX-1056 doesn't implement properly. When the receiver accepts 2.0 from my cable signal on...
        07 February 2005, 11:41 Monday
