Avatar too small
  • bleeding ears
    • 435
    Avatar too small
    Hi, I am having trouble getting my avatar to a proper size (too small).
    I am no computer whiz so please take it slow if explaining things.
    I set my scanner and anything else I could find to the lowest resolution and managed to get a very small picture up but cant get it to upload any larger.
    Any ideas? I assume that this avatar would be acceptable as I own Energy speakers.
    Thanks Peter
  • Paul H
    • 904
    I'm no computer expert, but it appears your picture size is too small - 32 x 42 pixels - upsize it a little and reload it.
    Paul
    • Kevin P
      • 10812
      So you scanned the avatar yourself? Did you resize it afterward, or did it scan directly to that small size? Try scanning at a higher resolution, or size it larger. Avatars can be up to 150 x 150 pixels, so you can go a bit bigger than you did.
      When I scan, I normally scan at full resolution, and then downsize the image afterward to fit whatever I'm trying to put it in. So, if I were scanning an avatar, I'd start out with a big image, then I'd resize it to fit the avatar size in Paint, Photoshop, Paint Shop Pro, or whatever you have.
      • bleeding ears
        • 435
        thanks guys, I will try again soon with your suggestions.
        thanks Pete
          • 27460
          we can resize it for you if you can send us a larger, better quality image. This one is to small and poor to enlarge. I tried.
          • bleeding ears
            • 435
            Doug this may sound silly but how would I send it to you? email?
            thanks Pete
            • Kevin P
              • 10812
              You can email it, or if it's under 100K in size, you can attach it to your post. If you're using the Quick Reply, click Go Advanced, then Manage Attachments. You can upload your image here and post it in this thread, then one of us can grab it and resize it for you.
              • bleeding ears
                • 435
                How about this image? anygood?
                Pete
                • Kevin P
                  • 10812
                  Try these on for size.
                  First one is your image, resized without any cropping.
                  Second one has some cropping.
                  Third one has more cropping (cut the name out so the speaker can be bigger).
                  • bleeding ears
                    • 435
                    The second one looks good to me and definitely better than what I originally had.
                    I spent a few hours again trying to get the avatar up there and for some reason it just didnt work.I dont think it is anything to do with the system its just me not knowing how to do it, or resize it etc.
                    Kevin if you could get it on there for me you it would make life a lot easier for me. I will have to learn more about computers.
                    Thanks Pete :T
                    • Kevin P
                      • 10812
                      Ok, done. Nice lookin' speaker too. :T
                      • bleeding ears
                        • 435
                        Well done Kevin, great work and thankyou very much
                        Pete
                          • 27460
                          nice job Kevin, that came out nice for Pete.
                          • augerpro
                            BBV2: a small format sub/sat system
                            by augerpro
                            FINALLY got my BoseBuster sequel done and written up!! I've shortened the name to BBV2 so I don't get any hassle from Bose. Next I'll be finishing the Scan Disco TM and MTM, the other flavors after. My Soma Sonus site is now hosting my projects. Here is copy of that page:
                            03 August 2014, 18:14 Sunday
                          • JonW
                            What are your favorite low volume (small) inductors and caps?
                            by JonW
                            Hi Folks,
                            After a long time away from speaker building (I had a kid), I’m getting back into it. The current project is a quite small speaker, with an internal volume of only 5 liters. I’ll start another thread on the design and goals after things are farther along.
                            Due...
                            14 February 2013, 10:34 Thursday
                          • MaxTimeOff
                            Advice on B&W rears for small HT
                            by MaxTimeOff
                            I am not an hi-fi aficionado but bought the following setup about eight years ago (at the behest of a friend). The following equipment has been in a seldom used TV room where we have not really appreciated its capabilities. We occasionally fire up the TV but often do not turn on the other sound components....
                            24 January 2005, 23:20 Monday
                            Retro Digital comes to town: The Avatar CD Transport from Denafrips
                            Do you ever see something on the web and right away, your first reaction is "I gotta have one, muy pronto!"
                            For whatever reasons, the new Denafrips Avatar CD transport struck that chord for me.
                            As an aside, how many of you knew that in 2019 vinyl outsold...
                            25 September 2020, 10:14 Friday
                          • JonW
                            designing small speakers for near field listening (e.g., desktop)
                            by JonW
                            For my next project I’m thinking about making some rather small speakers for use in an office-based system. Maximum size on the order of ~6.5” wide x 10” tall x 8” deep. And try to make as high end of a design as possible with low distortion and such. Given that the listener will be closer...
                            14 September 2008, 12:23 Sunday
