Hi Folks,
After a long time away from speaker building (I had a kid), I’m getting back into it. The current project is a quite small speaker, with an internal volume of only 5 liters. I’ll start another thread on the design and goals after things are farther along.
Due to the small cabinet size, I prefer not to rob the woofer of any more volume than needed by using huge caps and inductors in the crossover. I’ve noticed that, for example, on a prior project when I moved from Solen caps to Clarity Caps, the volume for a given uF cap value went up a lot. The Solens might be good to work with. For a given uF value are there other caps that are small and sound good to consider?
My last project also used 14 gauge air core inductors. Like the Clarity Caps, the big inductors are nice, but large. For a given mH value are iron core and/or higher gauged air core inductors smaller? Any compromise in sound quality (other than increased DCR)?
I’m using pricey, low distortion drivers so I want to use good quality crossover parts. Just wondering if there are any out there that you like that also happen to be small (of low volume) for a given uF or mH value. Thanks!
Here is a preview of the project. Note the CD case in there for scale.
