Advice on B&W rears for small HT
  • MaxTimeOff
    • 12
    I am not an hi-fi aficionado but bought the following setup about eight years ago (at the behest of a friend). The following equipment has been in a seldom used TV room where we have not really appreciated its capabilities. We occasionally fire up the TV but often do not turn on the other sound components. Here's what we have:
    B&W Power subwoofer - V75 MK2
    B&W (2) DM 601's speakers with stands
    B&W CC#6 center channel speaker
    Yamaha RX-V692 receiver.
    We also have a DVD player and CD player but we'll replace those with the latest and greatest.
    I am planning to move everything to a 10' x 11' room that will be a dedicated media room featuring a 50" HD plasma. I want to create a surround sound so I think I will need some additional speakers to mount on the wall/ceiling for the rears. I am planning to use the existing speakers for the fronts and center.
    Now for the questions. What (B&W) speakers should I get for the wall/ceiling rears? I don't want to use the 601's for the rears as they are too big, need some small "Bose size" (pardon that) wall mount speakers. Also, will that Yamaha do or should I replace it? It has hardly been used and I would like to use it if it would push all these speakers.
    Thanks in advance for your suggestions.
    MaxTimeOff
  • Aussie Geoff
    • Oct 2003
    • 1914
    Max,
    You have a few choices.
    B&W have some nice ceiling speakers such as the CCM 65 and CCM 80 you may want to consider.
    Wall mounts there are the DS6 dipoles...
    If you want small white speakers there are the LM1s
    You could also consider the 600S3s
    See you dealer re these options..
    The B&W Web site has more details on all of them....
    Geoff
    • bcgator
      • 57
      Max, I'm going to make a suggestion that may save you some money. I have a small room like you, with a pair of B&W 805 Signatures up front with an HTM2 center.
      I needed rears as well, for surround sound. But didn't see a point in spending big money for a small room. So I took a chance on a pair of Wharfedale WH-2 dipole surrounds. Don't laugh....but they only cost $89 per pair, shipping included, from Bestbuyplasma.com. You can get them in maple, white and black.
      I bought them figuring, if they suck really bad I'm only out $89. Pretty low risk purchase. Would you believe they actually sound really good? I was completely surprised, and I kept them. Their build quality is outstanding, they look more like $300 speakers than $89 speakers. And they sound very nice. Trust me, you're going to be very skeptical...I sure was. But you may also be ask shocked as me.
      I know you asked specifically for B&W speakers, but I thought I'd throw that suggestion out there. They work great for me. And they may save you some money, that you could spend on other things. Don't forget, in a surround sound system, there's not as much information coming from the rear channels so you don't need to spend a ton of money for nice sound from the rear.
      BCGator
      • fauzigarib
        SSP 600 - no rears...
        by fauzigarib
        Hi there,
        Not really a Classe owner, but I have an SSP 600 which I'm currently evaluating... And so far, the results are quite good.
        However, I'm running into a small problem, which I can't for the life of me figure out; the rear speakers don't fire in playback.
        12 October 2010, 00:00 Tuesday
      • familiar1985
        What surrounds and rears to pair with B&W 803d for 7.1 setup?
        by familiar1985
        Ok, so I have decided to go with B&W 803d as my mains. Trying to decide what center and surround speakers to pair with them for 7.1. For the back speakers i can only do In ceilings. For the surrounds i can only do in walls with limited space (also they would be not in optimal position either 5'...
        19 December 2010, 16:28 Sunday
      • brendon
        any one using ccm series in ceiling speakers?
        by brendon
        Hi All, I am currently loooking at rear speakers to use in a small room with 602s3 fronts and I am considering 600/601 rears or looking at CCM65 in ceilings .Is anybody able to comment on the CCM series and how would they stack up against a 600 or 601.The main reason i am looking at in ceilings is that...
        01 March 2005, 17:59 Tuesday
      • av neophite
        Need receiver for CCM series
        by av neophite
        I need your recommendations for a new receiver to match (3) CCm 817's (L,F,C) and (2) CCM 80's (rears). This will be our primary system, movies, music, tv, games, etc. Need 5.1 and a second zone for outdoor speakers(WM2). My goal is to stay under $1,500.00 if possible. I'm aware that most of you...
        02 January 2006, 22:47 Monday
      • sikoniko
        b&w CCM 817
        by sikoniko
        Versatile New Built-In From Bowers & Wilkins
        Sleek, Angled Design Adapts to Ceiling, Wall Locations
        B&W Loudspeakers, the British firm that stands as a leader in high-performance loudspeakers for custom-installation as well as high-end audio and home-theater systems,...
        28 September 2004, 15:21 Tuesday
