Proposed Statement II MTMWW Rebuild
  • DocT
    • Jan 2016
    • 10
    Hey guys.
    It's been about 4-5 years since I built my Statement II speakers. They've been excellent, though my craftsmanship has developed, and I'd like to rebuild them in a slightly more aesthetically pleasing manner.
    I attached a couple of photos of my CAD drawings. I've planned out how to do this with the CNC, I just want to check and discuss whether what I've proposed is reasonable, and wont impact dynamics too much.
    I intend to 3d print the channels for the mids, rather than use MDF. (this is why they are not included in the CAD drawings). It seems less complicated. I could make the mid tunnels round, or square as originally done.
    I increased the cabinet width by 1" at the woofers, and decreased it by 1" at the MTM.
    I haven't been able to calculate cabinet volume (likely due to some of my own weaknesses with Fusion 360). I left the depth the same. The height of the tweeter, and position of the mids to the tweeter is the same. I'd guess a 30-40% volume reduction, though hard to say. There's no port shown. I could go either way. No port, and add a sub. Or, port, and... probably add a sub anyway.
    Any input is appreciated. Click image for larger version
Name:	Screen Shot 2022-06-01 at 10.27.54.jpg
ID:	872648Click image for larger version
Name:	Screen Shot 2022-06-01 at 10.28.35.jpg
  • DocT
    • Jan 2016
    • 10
Name:	Screen Shot 2022-06-01 at 10.44.34.jpg
ID:	866855Click image for larger version
Name:	Screen Shot 2022-06-01 at 10.46.07.jpg
    A couple more photos for reference.
      • 15305
      Nice drawings. First thing, if you’re using the original crossovers, be sure the baffle width is identical.
      Second, I’m well known for being a fan of thicker baffles- been that way since the late 70’s. Probably 1870’s, realistically!
      What materials are your considering constructing with?
      Third, what is your thought behind the really thick baffles at the top and back of the midrange/tweeter module?
        • 15305
        Second, I’m well known for being a fan of thicker front baffles- been that way since the late 70’s. Probably 1870’s, realistically! This is where the maximum vibration stress is occurring. Take a look at the Wavecor Ardent threads, will give you an idea of what I’m talking about.
        • audioslave
          • Oct 2003
          • 34
          Don't the Statements have an open back mid? I think there are supposed to be tunnels behind each mid as well.
          mike
            • 15305
            Good point!
            • DocT
              • Jan 2016
              • 10
              Hey Mike, I mentioned this in the original thead:
              • DocT
                • Jan 2016
                • 10
                The back thickness is a.trick of cross section analysis I did. It's actually only .75" (19.05mm) thick. The top is thicker, since to get that shape I'll likely have to use my CNC for that specific component. So, I'll take a thick piece of stock, and mill it down to a curve.
                I intend to use MDF, and likely hardboard for the sides.
                I was hopeful that a less than 10% change in baffle thickness wouldn't be too impactful, and crossover changes wouldn't be necessary. However, I am happy to make some slight crossover adjustments if mandatory. If anyone can point me in the direction of decent quality reading material/resources that would suggest what changes to make. It's about time I learned a little more about crossover construction anyhow.
                  • 1892
                  Hey DocT, it seems that Fusion will give volume measurements when it thinks it has a nice solid object. More then likely I don't know how to do it either, but, when I need a volume number I take a side profile of the cabinet and extrude it to the appropriate width. I use the new body for nothing more than calculating volume and hide it when not needed. You can then take a measurement on the object and get a volume that way. Of course you need to subtract any internal bracing, etc.
                  Hopefully that all makes sense.
                  • Absinthe
                    • Sep 2021
                    • 48
                    If Fusion360 doesn't detect a closed volume to calculate, you can cheat by getting the surface area of either the top, bottom or one of the internal bracing plates and multiply by the height of the internal volume. Since you have voids in your internal baces, you'll have to select them along with the brace material before calculating the surface area otherwise, Fusion will omit those voids
