Rotel RDV 1060 problems
  • Murph
    Hi there folks have a few problems with my rotel RDV1060 would appreciate it if any of you have a heads up or advice on any of these problems.
    Thanks :T
    1. When i turn the unit off by the 'power off' push button switch(on the unit itself)say overnight - then when i start it up with a cd in dvd player, it hangs with the display saying loading, can only eject the cd by powering off the player and ejecting the cd before it trys to load, i then leave the player for approx thirty mins it then will play the cd.--works fine with dvds--
    2. I have a copy protected cd's (ie-it can not be copied thru digital only thru analog means,these are newish cd's that have a triangle symbol)--- but this cd only works after maybe ten ejects and replay, usually it will play approx 2 mins of the cd in silence, almost like fast play and will only then start playing.Copy protected cd's work fine on my other cd dvd players.
    3. Some cd's will not work at all just say loading on the display at all times there is only two out of three hundred like this--- but these cd's work fine on my other cd dvd players.
    4. With the scart lead connection,connected from dvd to the television(old crt sony) the audio is fine for dvds--- but if i leave the scart connected i can get no audio output from my television, must disconnect scart lead to get audio.
    --I have tried many other scart leads with the same result--
    I have read elsewhere of similar scart problems on the forum
    ---I have used other dvd players with my home entertainment system and i have had none of these problems---
    ---I have tried every possible config thru th menu system and cannot fix any of these problems---
    I have sent this to rotel support recently have not heard anything as yet.
    thanks for reading don't forget to send your problems ther to if they get enough people maybe they'll get a fix for these sooner.
    Thanks for reading..
  • Vicente
    Problems with RDV 1060
    by Vicente
    I bought a RDV-1060 about a month ago that is great in sound and vision, but I'm getting some problems that doesn't make me feel happy at all with it.
    - I get the same problem that many people reported with b&w images on other but the main TV, using the S VIDEO or composite connections...
    30 July 2004, 02:14 Friday
  • nvdeynde
    Rotel RDV 1060: Audio Decoders output,goto & other problems after software upgrade
    by nvdeynde
    My RDV 1060 had firmware 2.0.8 and I know this one has several problems with DVD-Audio discs and progressive scan.
    I assume the latest software available now is 2.1.2
    I have a few questions to owners with that software installed:
    1) How is the...
    26 May 2006, 06:11 Friday
  • Greg K
    RVD 1060 switching to SCART mode....
    by Greg K
    I have had the RVD 1060 since last fall,and very intermitantly on power up,it will be in SCART video mode,so therfore no pic over componant.To get it back ,have to switch to interlaced and get just enough picture to access the OSD and reset it.I have read of a couple people on here that have had similar...
    30 June 2004, 19:37 Wednesday
  • emcclaimsguy
    DVP-CX985V laser replaced and DVDs will not play after a few mins
    by emcclaimsguy
    Sony DVP-CX985V optical pickup replaced. The laser now reads CDs fine, but on DVDs will read fine for about 5-10 minutes and then the picture gets choppy and eventually. During the time the play is hesitating I can see the optical pickup is sort of pulsating off and on ever second or so and after about...
    16 January 2010, 16:20 Saturday
  • Marcel54
    Problem with RDV 1060 and SCART
    by Marcel54
    I have a complete Rotel set up (RSP1098, RDV1060, RB1080 and RMB1095) and I'm almost completely happy. But I do have a problem. Due to my TV I'm using the SCART connection from my DVD to my TV and there lies the problem. If my DVD is set to SCART my TFT from my RSP1098 is only monochrome (so no colours...
    27 March 2004, 04:21 Saturday
