1065 Problems
  • renzo
    • May 2003
    • 10
    1065 Problems
    After purchasing the 1065 last January I started to hear rackling from the front left part of the 1065 when I manually turned the power on after it had been off for a day or so. I did not hear the crackling when I used the remote to turn the power on. Also...certin letters on the display were beginning to fade (e.g. Mute, Dolby Digital Ex, etc...). I asked the dealer if they knew what was wrong. Although they were aware of the display problems on this model, they could not identify the crackling. I sent it to Rotel who replaced the display and said they fixed the problem, however Rotel could not identify the crackling problem. Does anyone have an idea what would cause the crackling? I am concend and disappointed these problems occured after only 2 months of use. To top it off the dealer didn't have a loaner for me to use during the past 2 weeks. Has anyone experienced these problems? Your thoughts and comments are appreciated. Arghhh!!!
  • Rock Dog
    • Jan 2003
    • 417
    It sounds like a dirty, or defective power switch. Based on your description.
    -Thomas-
    The easiest way to find something lost around the house, is to buy a replacement.
    Hey You! Make sure you stop by the HTguide Off-Topic section. It's FUN!!!
    -Thomas-
    As long as people will accept crap, it will be financially profitable to dispense it.
    Hey You! Make sure you stop by the HTguide After Midnight section. It's FUN!!!
    • renzo
      1065 popping!!!!
      by renzo
      Boy...more problems with my 1065...left front channel is popping and crackling. Also, certain letters in the display are fading again after returning product to Rotel. Considering the $ I spent I am very concerned about this product. Has anyone experienced this problem and if so how was it resolved?...
      28 September 2003, 14:53 Sunday
    • mj662
      1065 email rotel if you agree!
      by mj662
      Please let Rotel know if you agree with these issues I have. let me know if you think I am crazy!
      My main problems with this processor is that when watching TV I change a channel the sound drops out! The 1065 seems to think about what signal is available when simply changing the channel....
      08 September 2004, 16:29 Wednesday
    • Snatchfrigit
      Help with RSX 1065 / RDV 1060 / RB03
      by Snatchfrigit
      I have a few problems with my set-up...............
      Some of the pixels on the display of the RSX1065 are dull, this is the 3rd display in this unit and they have all gone the same way. Has anyone had the same problem? The RDV1060 sometimes misses a few seconds at the start of a track when playing...
      22 January 2006, 18:25 Sunday
    • James Edward
      RSX-1065 Gets Hot and Has Various Problems-Anyone Else?
      by James Edward
      My friend's 1065 receiver(6 months old) seems to overheat and two things have happened:
      First off, the unit won't respond to commands to adjust volume. This would happen after running it for 4-5 hours at volumes in the 60's.
      More recently, after a couple of hours at volumes in...
      13 June 2003, 23:37 Friday
    • deloner
      RSP 985 crackling noise
      by deloner
      I just bought a Rotel RSP 985(i use it with RMB1075).It was a demo unit.When i turn the volume knob, or change source, you can hear a crackling noise in all the speakers.It sounds electrical as static electrisity (sorry about the spelling).When i play music,watch movies there isn't a problem.It's just...
      25 September 2003, 06:58 Thursday
