Calibration-Problem
  • DB
    • Apr 2003
    Calibration-Problem
    Though I have adjusted the Soundoutput on all Speakers of my RSP-1066 on my desired values, I always receive a 3db higher output on my center-speaker when using my DVD (when I use other Inputs -Sat, or TV, I get my preset values)...
    Why is that?
    • 16507
    How did you set the inital values? Using the internal test tones? I've noticed that with Avia I sometimes get a slightly different reading between the test tones, and even within Avia's various tones so I usually take an average of them all which seems to work for me
    • Kevin D
      • 4601
      Also check your DVD player settings.. Most Panasonic players have a Center EQ mode that bumps the center output up a bit to "hear to quiet passages in movies.." You'll want to disable anything like that..
      Kevin D.
