This all started in the Dayton WTMW center channel thread, but I thought that some xover help was needed and apart from the project thread.
Inductors: In schematics I see ohm values and mH values.The mH values are easy to find and by adding together in series or parallel they work.The problem I seem to be having is the ohm value as stated on the published schematic.When ordering the parts, the catalog does not jive with the values of the project.A little explaination on the values and how to select proper chokes.Should I also choose a coil based on ga./watt rating or does the ga. indicate the ohm value ? I would like to stay faithful to the great designs in this forum, but sticking to it is tough when I'm unsure on these questions.
I think I read in the other thread that resistors add value in series and divided by two when in parallel.Is there any way to use odd values to create the desired value for the project ? If so what formula is used ?
About values, if the desired value of a capacitor is 9.5uF for a xover, can I use a 10uF cap with little change in the sound ? How far can I deviate from the project value before I cause real problems.
Last, caps are the oposite from resistors, they add value in parallel and divide by two when run in series.Do I always use equal value to get the desired cap or is there a formula to using odd values in series.
I know these are basic questions from a xover newbie , but I'm trying.If you guys feel this is better left in the Dayton RS center channel thread than by all means move it.Thanx.
KG
KG
