RMB-1585 Power Noise?
  • Gui0507
    • Oct 2020
    Hi all!
    Just took ownership of a new Rotel RMB-1585 200wpc. I’ve noticed it has a sight noise to it when it’s on, seems like electrical noise but not sure if it’s something more serious. I also can hear when starting up a sort of light rapid clicking sound,
    I haven’t been able to tell if it’s only on startup, as last night I don’t remember the clicking part. I went ahead and disconnected it from my monster surge protector and plugged it directly to an outlet, it seems the noise is less but I am not certain as I had someone do
    It while I was on the phone. According to them, it’s heard when you are close on top of it, sitting back you can’t hear it.
    Probably just paranoid , I’ve never had a separate amp before. This is paired with the new RSP-1576 MKII processor. Is there any power conditioning that should be used here? Some people say it’s best connected direct to a wall outlet.
    Thanks!!
    there should be no noise.
    have you mentioned this to the place you purchased it from?
    • prk504
      Rmb1585 floor noise?
      by prk504
      Does anyone experience a slight him from the tweeters when using the rmb1585?
      I have a slight hum with no audio coming through..I've tried disconnecting all the interconnects and the trigger. The amp is plugged into a Tripp Lite Lc1200 and I've tried plugging it in directly to the wall....
      19 July 2017, 00:17 Wednesday
    • TimbaLand
      Upgrade to RMB1585
      by TimbaLand
      Hi guys
      I have an RMB1095 and I have an opportunity to replace it with RMB1585. It's gonna cost some money to do this but I'm getting it at a good price. More like 40% off retail value. Is it worth it or this is just a waste of money?
      24 June 2014, 10:51 Tuesday
    • TimbaLand
      RMB1585 balanced inputs
      by TimbaLand
      The RMB1585 has RCA and XLR inputs. I have heard before that the XLR inputs in Rotel are not truly. balanced. Os it the case with the 1585?
      25 July 2015, 02:43 Saturday
    • Spectre
      RSP-1066 and noise from LS
      by Spectre
      Hi all,
      I am a new owner of the Rotel RSP-1066 and the RMB-1075 combi.
      All in all I am very pleased with this combi as it is a significant improvement over my old Yamaha AZ-2 amplifier.
      However, I noticed a little annoiance that is not noticeable under normal...
      02 September 2004, 03:51 Thursday
    • mikeyo
      RCD-1072 spinning noise
      by mikeyo
      Long time lurker here but this is my first post.
      I've recently upgraded everything I got to Rotel equipment and am loving every bit of it but I seem to be having a bit of a problem with the RCD-1072.
      With some CDs it seems to be making a kind of clicking or loud spinning...
      29 January 2006, 11:52 Sunday
