RC-1570 PC-USB cable/connection
  • RonLenker
    • May 2015
    I recently purchased an RC-1570 pre-amp as a replacement for a RC-972 in a stack of 2 channel Rotel gear. Before placing into service, I was persuaded to provide the ability to spin some vinyl at the beach with some college friends, so for the time being it is feeding some KRKs and a REL sub. Besides pulling the old vinyl off the self I have also been moving to 24/196 source material and installed the drivers provided to allow this from windows with FLAC files via JRiver. This has been a real treat and cemented the decision to demote the old method to phone support. My issue and question has to do with the USB input connection from the Laptop. When using the cable provide and placing the laptop directly in front of the pre-amp everything functions properly, but when I switch the cable for one (i.e. 6 ft.) that lets me sit back a few feet I start hearing a relay switch and the music playback is momentarily interrupted, which I assume is a reset, and caused by something like a timing or sync issue. I tried new and supposedly high quality cables with no success. Does anyone know if that is the issue or if converting to isolated fiber, purchasing a specific cable, etc. would allow working around this? For that matter, will the optical inputs function in the same way the PC-USB does? Thanks in advance.
  • Patrick Butler
    • Jan 2014
    • 164
    Hi RonLenker,
    Thank you for purchasing an RC-1570!
    When you swap one USB cable for another in a system that is already on and operational, you should hear a relay click. However, that click should happen once (as everything synchronizes) and not continuously as the music plays. There is nothing inherently special about the supplied USB cable (other than it working.) I routinely use a longer USB cable (2m) with the RC-1570 and RA-1570 (they use the same DAC section) and have no issues. That said, I have used some USB cables in the past that were not designed correctly and caused issues with a variety of DACs. Feel free to drop me a PM if you have any more questions.
    Patrick Butler
    B&W Group North America
      Well I guess it's true... a USB cable can make a difference.
      by PewterTA
      This is the third upgrade I've done. My original cable was just a cheap USB cable I got from who knows where and it worked sounded good and no complaints.
      This all going to my Musical Fidelity V-Link 192.
      Then I upgraded my usb cable to a Wireworld Ultraviolet cable and...
      27 August 2013, 21:28 Tuesday
      Mutec MC-3+USB - the real deal
      by PewterTA
      Anyone that is looking to improve the sound from their media pc, be it Windows, Linux, or MAC... (and hasn't spent a ton of money on some other USB to SPDIF solution)... I highly recommend taking a look at the solution from Mutec.
      The new MC-3+ USB is 'essentially' the original MC-3+ Master...
      19 April 2016, 21:13 Tuesday
    • RotelBorn
      Humming sound from Rotel RT-1570 (USB-plugged in)
      by RotelBorn
      I'm new to this forum. First hit on Rotel Forum, was this site. I hope someone can help me.
      Bought a Rotel RA-1570 (not RT) a few years ago, when it was new. And earlier this year I bought a USB-cable to connect my computer to it. because I wanted to try not using the Toslink...
      28 September 2016, 11:01 Wednesday
    • grandsvaux
      Which USB-AB to buy ??
      by grandsvaux
      Hi Guys,
      Looking for some guidance in the purchase of a new USB-AB Digital cable any recommendations on a good quality USB cable my
      sauce is a mac going to a classe ssp thanks in advance.
      06 October 2016, 13:16 Thursday
    • gerardhn
      Using USB port on CP 800
      by gerardhn
      HI,
      This fantastic new feature (asynchronous data transfer to the DAC) is not much discussed on the forum.
      Means that maybe not that many users in the forum do have the CP 800 or they use the coax or optical in.
      I use it as well as for pc playing as with the logitech touch,...
      13 October 2012, 23:37 Saturday
