Very Strange Sound - RSX-1550
  • toofar
    • Sep 2011
    • 11
    So this has happened twice in the past 6 months, very weird. I'll be playing a video game, MW2 & MW3, and out of nowhere I get a noise that kind of sounds like when you're plugging a guitar into an amp. It's hard to explain, hopefully there are some musicians amongst us. So I have to turn the unit off for about 30 seconds and then the noise goes away. Any ideas? Has this happened to anybody? I'm tossing the idea around of just taking it in since it's under warranty, but that means I'm SOL for who knows how long, since I have no back up receiver. I just sold it. Figures.
  • Kevin D
    • 4601
    Sounds like the digital signal is losing lock and not decoding right. Using HDMI? Have they latest updates on it?
    Kevin D.
    • toofar
      • Sep 2011
      • 11
      Yes on the HDMI and not a single update. I've been meaning to do that. I'll update this weekend and see if that fixes it. Thank you for the reply.
      • madmac
        • Aug 2010
        • 3122
        That sounds like the beginning of the famous Rotel "POP" !!. My Rotel receiver did that for awhile and then quit altogether. It would only work with no digital processing in "analog bypass" mode. It's a digital stage issue on Rotel receivers. It's sad to see that they have not addressed it on their newer Receivers. Depending on how much warranty you have left, you might want to bring it in for repair. This issue is not going to go away and will likely only get worse. Besides, the pop noise is bad and depending on your volume level, can actually damage your speakers!!. Another sad piece of news is that even if you send it in for repair, they will likely not cure the issue. The reason for that is that you have to operate the receiver under 'load' and actually power speakers with it to experience the phenomenon. Rotel will not do that at the shop. They will make 'assumptions' as to what the issue is, change some parts, do some diagnostics and firmware updates and ship it back to you. If you have lots of time left on the warranty, keep using it until it craps out altogether. Reason for this is that you will lose your Rotel for a solid month when you send it in. Check out some other Rotel repair issues on this Rotel forum and you'll better understand what I'm talking about here. One BIG piece of advice I can give you is that, make sure your Rotel in plugged into a well GROUNDED socket with correct polarity, and make sure that connection is using a good Spike bar power bar/conditioner in between them.
        Dan Madden :T
        • toofar
          • Sep 2011
          • 11
          WOW! That sucks if that's the issue. The noise is a continuous sound, not so much a pop. The sound is very similar to the noise that is made when say you're plugging in the cable to a subwoofer. Kind of like a VVVVVVVV sound. I will check this forum. I searched the Rotel Update software and there are a couple of "lock" issues that they have addressed in updates. So I'll do those and cross my fingers. I'm using a Furman PST8. It's definitely saved me more than once from voltage issues. Thanks for the heads up.
          • toofar
            • Sep 2011
            • 11
            And now it has just had it's first video loss. The screen lost the picture for about 2 seconds. This unit was flawless for years. I have never dealt with Rotel regarding a warranty issue. If they can't reproduce the problem are they going to tell me tough s*** or will they repair it based off my claims?
            • madmac
              • Aug 2010
              • 3122
              They will 'attempt' to repair it. It may work or it may not. When mine came back it worked........for about 6 hours or so......then.....POP goes the weasel!! :-)
              They eventually gave me a refurbished, newer model that has worked flawlessly ever since. Thumbs crossed!.
              Dan Madden :T
              • toofar
                • Sep 2011
                • 11
                Okay, so I updated the firmware about 2 weeks ago and the strange buzz noise has not occurred again, so far, BUT now I get an insane amount of distortion when there's an explosion when playing MW3. I seriously doubt it's my speakers, is it possible that the firmware update is the cause of this? And if so, can somebody explain why this happens?
                • Kevin D
                  • 4601
                  Did you update all three firmwares if needed? They work together. The latest main without the latest audio can cause problems.
                  Kevin D.
                  • toofar
                    • Sep 2011
                    • 11
                    Thanks for the reply. I do have all current firmware updates. The bad news, the sound has returned, BUT my girlfriend heard the same sound coming from her PS3, so I believe it's a PS3 issue. Maybe the distortion is also a PS3 issue?
                    • fjhuerta
                      Strange problem with crossover construction... is this the drivers' fault, or...?
                      by fjhuerta
                      Hi all!
                      I was building a couple of crossovers when something strange happened. When I measured impedance plots, they were both identical - except for a tiny region, from around 1000 ~ 1300 Hz. They measured significantly different - one of them was 3 or 4 ohms higher than the other. The...
                      01 February 2007, 14:51 Thursday
                    • Willempie
                      Rotel RSX1550 problems
                      by Willempie
                      Thanks for having this forum as it is appreciated. I have a RSX1550 that has previously required repairs which involved some amplifier circuit board replacement done at a non Rotel facility. Now I have other issues on which advice of any kind would be appreciated. Outputs for two channel such as stereo...
                      29 December 2017, 12:21 Friday
                    • kneptune
                      rsp1098 dead after v1.1.6 firmware update
                      by kneptune
                      New member, first posting. Have been a outside observer to this forum for a short time and have been gleaning good information -- excellent forum! Long time Rotel fan and hi-fi addict since high school in the late 70's.
                      I just purchased a RSP-1098 with version 1.1.4 software and decided...
                      12 January 2004, 13:14 Monday
                    • fnou2
                      6.1 settings
                      by fnou2
                      Hey Guy's
                      I have a dedicated screening room and so far I have been using a 5.1 system. Recently I bought a new central speaker and since my material (rotel and nakamichi ) allows me to add speakers, I tried putting a 6.1 system.
                      I had two issues:
                      1 - I used...
                      21 May 2004, 09:20 Friday
                    • dali
                      RSP 1066 suddenly sounds bad in 2ch analog
                      by dali
                      I have had a RSP 1066 for about 30 months and yesterday something strange happened. I turned everything on to listen to a CD and the sound was all messed up, kind of difficult to describe but it's something like listening to headphones held 5 inches from your ears. All bass and most of the treble is...
                      02 March 2005, 06:58 Wednesday
