Hi all!
I was building a couple of crossovers when something strange happened. When I measured impedance plots, they were both identical - except for a tiny region, from around 1000 ~ 1300 Hz. They measured significantly different - one of them was 3 or 4 ohms higher than the other. The overall shape of the curve was identical everywhere else.
I thought I had a cold solder joint, so I reheated every union. No luck.
I then disassembled both crossovers and reassembled them onto a larger board (to avoid inductor interaction). Same issue.
Disassembled everything and measured every component. They measured within the spec - except for the fact that I think I saw a cap oscillating when I measured it. I moved the probes a bit and it stabilized. I re-measured the cap at the crossover frequency and it seemed to be fine.
When I tried to reassemble the crossover - well, what do I know, broke a couple of leads. I tried soldering some wire to them, but the damage was done.
I ordered every cap and resistor again.
But I 'm now wondering - is it "normal" to have a couple of components fail every now and then? Or should I worry and start measuring the impedance of every driver... could this be the problem?
