any difference in sound?
  • pmarb
    • 11
    Hi, just wondered if a 1572 for R/L duties would sound better than 2 channels used on a 1575? thanks
  • srb
    • Oct 2004
    • 311
    RB-1572 vs RMB-1575: Any Difference In Sound ?
    I have not compared the two amplifiers.
    But although they both have amplifier channels of 250W @ 8 ohm, the ICEpower modules and power supply configuration differ between them.
    The RMB-1575 uses two 500ASP modules with integrated power supplies for Left and Right channels. The ASP modules' power supplies are also used to power three 500A modules for Center, Rear Left and Rear Right.
    The RB-1572 uses two 500A modules that are powered by a separate Rotel-built power supply.
    The implication would be that under 5 channel use (or even 2 channel use ?) the RMB-1575 might not might perform quite as well as the 2 channel RB-1572 with its Rotel-built dedicated power supply.
    This is of course speculation, but why then would Rotel go to the trouble of building a separate power supply when they could have more easily just used two 500ASP modules with integrated power supplies for the RB-1572?
    BTW, it's always helpful to have a meaningful topic title, i.e. instead of "any difference in sound?", perhaps "RB-1572 vs RMB-1575: Any Difference In Sound?".
    Steve
