More frequently the sound is cutting out on my 1098. Happens with all sources. Will be fine for awhile then un usable. No local dealer anymore and hate to wait 2 months to ship back to rotel. Any suggestions? Thinking about replacing with onkyo nr 808 receiver.
Sound cutting out on 1098
Tags: None
Same problem with my RSX 1056
I have the same problem!. Do you hear a 'pop' or a 'crakel' sound before the sound cuts out?. Do the display lights stay on?.
Have you been able to fix it or contact Rotel ?
Let me know if you find anything out ok?
Thanks!Dan Madden :T- Bottom
I would say it's most likely something in the audio board. I would be tempted to remove it and use some deoxit on the connectors...maybe clean the Pre out, removing dust and what not. See what that does.
There is a store in Pittsburgh, PA that can probably look at it and get it working (I can get the service manual to them) for you. Though I don't know how busy they are... I think things are going well so they are busy, but not authorized by Rotel... so you won't pay the high prices for repairs that Rotel will make you pay for.
Vintage HiFi of Pittsburgh is all you need to search on.Digital Audio makes me Happy.
-Dan- Bottom
by Swilliams97I have a new 1098 with both DVD and Scientific Atlanta cable box connected with Comp cables and using video switching. Time Warner Cable suggested setting cable box for 1080i output only and when the 1098 was set for progressive output I got horizontal lines and distortion at the top of the screen,...-
Channel: Club Rotel
by sramsayHi All,
Well I finally did it and upgraded my RSP-980 and RDA-975 to the RSP-1098 using a Rotel RB-985 AMP.
First of all, the new processor is a beast. The 2 channel music is great and the surround sound processing is magic in comparison to my old gear.
I...-
Channel: Club Rotel
Godsmack's New Live Concert Movie DVD 'Changes' Mixed in SRS Circle Surround(R) 5.1
17 September 2004, 1:29pm ET
Circle Surround Is the Surround Format of Choice for Leading Recording Artists
Creating Surround Sound Music and Video Productions...-
Channel: In Tune - All about the music
29 September 2004, 16:58 Wednesday -
by HenkI use two 12v triggers on my RSP 1098, one triggers a RLC-1050 power distributor (which in turn powers on a RB-1090) while the other triggers a RMB-1075. Everything worked fine until a few weeks ago when the RSP 1098 started to interrupt the 12v trigger to both components at random after power on. When...-
Channel: Club Rotel
by CGMI am new to the forum and just received some evaluation gear to test in my HT. I received a 1075/1098 combination that am running with B&W 805's. This is my second day working with the set up and I can not get any sound from my center channel at all. I had it working fine orignally and then it...-
Channel: Club Rotel
- Loading...
- No more items.
