ROTEL RSX-1056 no centre sound on 5.1 inputs
  • paazel
    • Apr 2007
    • 10
    Hello I have a Rotel RSX-1056 connected to my Panasonic DMP-BD80 via Coaxial (Digital) and also 5.1 (Analogue). The sound comes through clearly via all speakers when on digital input; but when on 5.1, I have no sound through centre channel. I have tried new different interconnects, and have also connected centre out from Panasonic to other channel (left surround input) to verify that it is not an issue with my BD player. Is there a setting I am overlooking? I've read the manual front to back, but can't seem to figure it out. The firmware on the 1056 is 1.2.2 (stock).
    Thanks in advance.
  • Linki
    • Aug 2007
    • 18
    This might sound stupid, but I assume you checked if the Centre Speaker is not set to none in the RSX.... also have you connected the Centre speaker to one of the other speaker terminals just to make sure the speaker works (highly unlikely that the speaker is bust, but worth a shot)
    good luck.
    • srb
      • Oct 2004
      • 311
      If you re-read the original post, there is sound through the Center speaker when the Panasonic player is connected via a digital cable, so obviously the Center speaker is working and the receiver's speaker setup is not set to Center = None.
      Regardless, the analog 5.1 inputs bypass everything (including individual speaker enabling) but the volume control, and the signals are sent directly to the preamp and speaker outputs. Since you have verified that the player's analog Center channel output works by plugging it into the receiver's 5.1 Left Surround input, it does sound like the analog 5.1 section could have a problem with the Center channel input.
      Also, the title refers to the RSX-1056 but you subsequently refer to it as the RSX-1560. I have the RSX-1056 and I am curious as to which receiver it is.
      Steve
      • paazel
        • Apr 2007
        • 10
        Hi, it is indeed the RSX-1056 (I've corrected the inconsistencies). I bought this receiver as an upgrade from the RSX-972 for the bass management & ability to sum channels to take advantage of DTS Master & Dolby TrueHD.
        • srb
          • Oct 2004
          • 311
          As I said, the analog 5.1 inputs bypass the internal DSP, and the only thing you can set for the multi inputs are the associated video input default and LFE redirection on or off.
          A couple things you could try (if you haven't already):
          1. Complete power down: Power down the receiver from the rear panel power switch, unplug the power cord, wait 5 - 10 minutes and power back on.
          2. Factory Reset: Although I don't know if a factory reset will accomplish anything relative to the multi inputs, that would be the second thing I would try. A factory reset will reset all of your configuration settings so you may want to try to save the configuration first (may not save all settings).
          In the Default Setup menu:
          To save configuration: Set User Default > Yes
          To reset factory defaults: Factory Default > Yes
          To reload saved configuration: User Default > Yes
          Again, I don't know if the reset will affect the multi inputs, but it couldn't hurt to try, as I don't know what else can be done except for internal servicing and checking for a faulty cable, connection, electrical component or board.
          Steve
          • paazel
            • Apr 2007
            • 10
            Thanks for your suggestions Steve, I'll try both & get back to you.
            • srb
              • Oct 2004
              • 311
              So did either of those get the center channel speaker working when using the 5.1 multi inputs?
              Steve
              • Paul H
                Seas centre (center) channel
                by Paul H
                I've finished (for now) some massive 4-way active dipoles for my mains, as captured in another thread. The speakers include a Scanspeak 9700 tweeter, a W18 (6.5") Seas Excel and two L26 (10") Seas.
                I want to build a matching centre, which would also be dipole and use a Seas...
                02 November 2005, 17:03 Wednesday
              • naive
                Centre Channel for Matrix 802S3
                by naive
                I've the old model of B&W Matrix802S3 with a pair of Odyssey monoblocks to drive. Now I'm looking for a front centre channel for the HT enjoyment. Which one of the following centre channel speaker is the best match to my old speakers:
                1) HTM7
                2) old version HTM1 (similar...
                12 August 2005, 18:01 Friday
                Magnepan "annouces" new centre channel
                by Andrew Pratt
                According to the Maggie user forum Magnepan is about to release a new centre channel speaker system. There's a link http://www.magnepan.com/mc1/ht.html that isn't yet a hyperlink of their site and there's no text yet so I gather they aren't ready to release this just yet but it looks interesting. ...
                24 May 2001, 12:45 Thursday
              • rick c
                speaker crossover settings/ rsx1056
                by rick c
                I'm not sure what to do here.I have a rsx1056 powering Def.tech.procinema 100's w/the 200tl sub.My spks are connected via speaker level and subout and set the fronts are set to large and the sub set at 80.This is the way "chet" at Def.Tech. advised in connecting these spkrs.They said you get...
                30 August 2004, 22:42 Monday
              • guibara
                RSX1056 Questions/Issues - Newbie!
                by guibara
                Hi there!!
                I've had my Rotel 1056 for a couple of months now (firmware 1.1.7). I have it hooked up to 2 Quads 22L and an L series Centre channel only. I have my TV, Cable DVR box, my DVD and my AirTunes connected to it (audiowise all coaxial except for AirTunes that uses Optical). I have...
                09 March 2005, 14:16 Wednesday
