Blown channel or speaker HELP
  • slyther3
    • 27
    Hello. I am having a seriously bad day. I have a Rsx 1067 receiver and I think I may have lost the center channel.... Is that possible and how can I be sure. My setup is Rotel 1067, 1080 2 channel for fronts, and Paradigm studio's front, center and rears. I have a B&W sub. I also am having a hard time getting the OSD to come up on the screen. All equipment is only a few years old and I never blast the music. two nights ago a loud buzz came out of the center speaker while playing the PS3 ( MW2) and my receiver will periodically go out with no sound. If anyone has an answer I would appreciate it. Thanks
  • htsteve
    • 1216
    slyther3,
    Bummer.
    For you center channel, do this test. Turn everything off. Switch the speaker wires, at the speaker end, with one of your mains, say the left.
    If your center channel amp in the receiver is out, then the left speaker will do nothing. You'll then know the problem. If you do get output in the left speaker, then it would be the actual center channel that is the problem.
    As to your OSD, that is wierd. Make sure the video cable you are using is connected correctly. Also, you can try and swap out that video cable. I'ts not often, but I've had a cable go bad.
    As for the reciever just shutting off, that definitely sounds liek an ionternal issue. Like the power supply acting bad.
    Rotel recievers have 5 year warranties on them from a dealer. Assuming you got it from a delaer, you would be covered for any repairs.
    Hope this helps.
    • slyther3
      • 27
      Thanks I will try that. What do you think the chances of the speaker being blown? I never abuse them. I'll also check with my dealer but they aren't that supportive usually. When you say speaker end are you meaning remove the wires from the receiver and switch speakers or are you saying from the speaker? Sorry I love audio but am not that technical.
      • htsteve
        • 1216
        Actually, simply switch the speaker wires at the back of the receiver. Just switch the center with the left.
        If it's to hard to get to the back of the receiver, then switch the wires at the speaker end. Unhook the wires from the left and center channels and switch them.
        • slyther3
          • 27
          Thanks I'll give it a whirl. I talked to my dealer and they said the same.
          • kid320
            Newbie needs help selecting receiver/speakers
            by kid320
            I apoligize in advance if my post is a little long, I am trying to give as much detail as I can. Please bear with me and feel free to skip over the parts you find aren't needed.
            Within the last few years, I have become quite the home theater junkie. My movie collection...
            24 October 2005, 20:27 Monday
          • rotel&energy
            Blown left channel (RB-1080)?
            by rotel&energy
            Hey guys,
            This is my first post in a long time, and unfortunately I'm going to open up an old issue - blown left channels on RB-1080s. I've had my 1080 for over 2 years, using the 12 volt trigger, without any problems. Just the other night, I came into the family room and noticed I...
            21 June 2006, 10:58 Wednesday
          • Cool Mr Steve
            Problem with H/K Receiver
            by Cool Mr Steve
            I currently have a Harmon Kardon AVR 340 and a pair of Swans 5.2 main speakers. I'm about to get a center channel for my system and build a set of surrounds, but I have an issue; When I "enable" the use of a center channel on my receiver the sound "oscillates," like there is a short...
            09 December 2006, 05:57 Saturday
          • palmetto
            attributes for av receiver? denon 3805 vs. others?
            by palmetto
            HELP!
            I am about to buy all the components for my media room with a 5.1 set-up. My wish list below reflects my general budget. My focus is on the receiver but other observations or comments on the other components are appreciated.
            Denon 3805 A/V Receiver 120 W x 7 (list:...
            12 February 2004, 17:38 Thursday
          • mitch57
            Parasound Halo A51 5th Channel Problem.
            by mitch57
            Well it looks like my Halo A51 Amp's 5th channel is on it's way out. I started noticing the the 5th channel, which is the surround right channel, didn't seem to have much of a signal. I first noticed it while listening to DVD-A and multi channel SACDs. It just didn't seem like I was hearing much...
            21 May 2006, 18:56 Sunday
