I updated the FW and had to redo my setup. Now when I am sending LPCM via HDMI using the sub setup test tones from Avia, the sub level for the rear speakers is like way lower than that front. Also the "MULTICHANNEL" setting in the sub setup menu seems to have no effect on the level as it did before for MPCM. I went from main 1.18 to 1.21. I think I may want to roll back to 1.18 or maybe try 1.20 as well.
Anyone have to old hex files???
Update 2/21/2010: Rotel released v1.22 this month but it did not address all the issues with HDMI Multi PCM audio. I have contacted Rotel and was told they will work on it further. For now though I suggest to go ahead and upgrade to v1.22 because there are sonic improvements over the previous version for HDMI audio. Be sure to upgrade your scaler to v1.48 FIRST.
I will keep this thread updated.
