I have a rotel rb-993 3 channel amp. Normally when i turn it on, i can hear the relay clicks before the amp turns on. But now, there's no relay click but the light comes on, of course the amp is not working. Could it be just a simple relay repair or can anyone direct me to where i should locate and replace the component.
rotel problem help!
Pull the chassis cover off and look for the fuses on the circuit boards. Replace them if you have slightest suspicion of their condition or check them with a VU meter. You can sometimes find replacements at RatShack or click the Parts Express banner on our site and order from them.
Otherwise, you will need to locate a repair shop with a good reputation or return the unit to Rotel’s repair facility.- Bottom
by saksagerI am the owner of the mentioned integrated amplifier and I have have used it for several years without any problems. Lately the amplifier has begun to switch off without any reason. When doing so it sounds like the stand-by relay is switching and it is not possible to turn the amplifier on again. When...-
Channel: Club Rotel
by duketbrd88I have a classe ca2200, cp500 and B&W 804s's. My monitor is a pioneer elite pro101fd and dish network is my service provider. I always watch tv through this system every night. I listen to tv with the volume on the cp500 at 35db. anyways i always hear a clicking sound every so often coming from...-
Channel: Club Classé
by tinnsoldatenHi everybody
I got a RSP 1098 that have the typical loss of signal via optical , no relay sounds when I change sound mode. I also have no sound if stereo/bypass. I had it once at service but they sent it back "all ok "
Now it worked for a short bit , but now...-
Channel: Club Rotel
by rystHave som issue with my M700 monoamps.
Since I bought the SSP600 , I have had some problem to power up my amps. The relay that usally click once after a few sec when you have powerd up the unit and lock the signal from the preamp just keeps shut on/off.
This process may take up...-
by TaitoHi, I'm working on the design of a preamplifier at the moment and would like to know if anyone has found some really good relays for switching audio sources, or has come up with a better way to do it -at this stage, the plan is to incorporate some form of microprocessor control (which I'm pretty sure...-
Channel: Mission Possible DIY
- Loading...
- No more items.
