Hi all, I have an RSX-1056 that I love, but the volume will sometimes jump way up or down when I try to adjust it. (For example you can instantly go from 31 to 66).
Is there a fix for this?
Also I had an odd issue last summer when I'd unplug it before a storm came through I'd go to plug it back in and it would forget all my programed settings (radio presets, preferences for sound, etc). This happened 2-3 times in a row and now hasn't happened again in 9 months. I'm curious if there is a solution for this issue, too, although it is less pressing since it has at least for now fixed itself, but with storm season coming ...
All that said, I love the way this machine sounds and it was the right purchase even if it has a bit of a temper sometimes.
I've never messed with the firmware, and perhaps this is the issue?
