Are there any differences between the RSX-1057, and the RT-1080 that would make a difference for pulling in weak AM stations?
Radio Tuner and Weak AM Stations
by BostonearsWhen I went to program my favorite radio stations into the tuner of my 1067, I discovered a problem (and a workaround) if a station is broadcasting with RBDS (station info).
Normally, if I tune a station (non-RBDS), when I push the Memory button on the front panel, I can enter a number...-
Channel: Club Rotel
by El CapitanMy 1055 is giving me trouble with picking up stations higher than ~100.0 on FM.
I have tried both my roof mounted antenna and the simple dipole that comes with the Rotel with the same results: it doesn't pick up these higher stations, and in fact, it will lock onto some station of a...-
Channel: Club Rotel
by banzaiiI just picked up an RSX-1065 a few weeks ago and finally wanted to listen to some radio. After I connected the stock antenna I was able to receive AM stations but couldn't get any FM. Even if I manually select the frequency I can't hear anything.
Could it be that the stock antenna is...-
Channel: Club Rotel
by kitjvI am looking for a tuner to integrate into my 2-channel system. Unfortunately, I live in an area with relatively few FM stations and, as of yet, no HD stations. Sensitivity would be a critical factor to pick up weak signals. Also, compatibility with a satellite radio receiver and HD signals would be...-
Channel: Audio Hideout
by H.T.CThere is a new radio thats to come out called the {it was to be called the grundig satellite 900} eton e1 xm that contains : 1) xm satellite radio and digital audio band which is the new broadcasting standerd that i think upgrades shortwave and am radio to almost fm sound quality in stereo and fm to...30 March 2004, 12:57 Tuesday - Loading...
- No more items.
