Problem with RSX-1055 ???
  • Tha Freak
    • Jul 2003
    • 385
    RSX-1055 won't power up ?
    Yesterday I watched Zodiac (7/10, sound was mediocre) everything seems OK...
    Today my son wanted to play with his Gamecube and called me at work to tell me the Rotel will not power up ??
    I tell him do this...do that...nothing works over the phone...I told myself that he must have tried someting or press a button and I cannot figure out, so I told him I will check it when I get home...
    I arrive at home and as he was saying, the Rotel won't power up ?? Here what it does, when I press the "ON" button on the remote to get out of the standby mode, a "pluck" occurs in the speaker immediately (½ sec) followed by a speaker "hum", a click in the Rotel then it goes back on "Standby"...
    I never had any problems with my older set up...
    now I have a new set up with a 56" TV...I added a Belkin PureAV line conditionner to protect the TV and other electronics, The rotel is connected in the "delay switched" outlet made for power amps or receiver from the PureAV...I was wondering that maybe the Belkin was bad...but I connected the Rotel direct in the wall...same thing !...
    It won't power up ???
    any clues ?
    "Are you gonna bark all day little doggy?...or are you gonna bite?
  • rick c
    • 430
    go to the switch on the back and turn off then on again.It will put back on standby and it should power back on.
    • Kevin D
      • 4601
      The 1055 didn't have a switch in the back, but unplugging the cord and plugging straight into the wall accomplished the same thing.
      Sounds like something wrong in the amplifier or power circuit. Have you tried removing the speaker connections just to make sure the receiver isn't going into protection mode from a bad speaker/wire?
      Kevin D.
      • Tha Freak
        • Jul 2003
        • 385
        unplugged everything, plugged the RSX alone in the wall....
        it was back on!!!
        reconnected everithing back, now all is quite fine...
        Thanks Kevin!! :T
        • Andrew M Ward
          • 717
          RLC-1040 should be your next purchase.... (STAT)
          • Tha Freak
            • Jul 2003
            • 385
            already have a Belkin PureAV PF40
            could this have been an issue ??
            and what do you mean by (STAT) ??
            • rick c
              • 430
              I doubt it,i have one also.My 1056 after i think was either a surge or spike would not power back on even though the stanby light was on.Had to switch off in the back and turn back on.It would do this every so often about 1 every 1-2 mos.I then picked up a pureav about 2 yrs ago and it's only happened once since.
              • Tha Freak
                • Jul 2003
                • 385
                do you connect it in the switched delayed hi-current "Amp" inlet or in the switched "Receiver" inlet ?
                • rick c
                  • 430
                  to be honest i believe it's on the reciever outlet.The delayed outlets if iremember correctly have to be set.I havent even loooked at the back since i installed it.When and if i add an amp that doesnt have a 12v trigger i'll try the delayed outlets.All i did was install and connect everything to the outlets and didnt even bother with setting any delay.
                  • Tha Freak
                    • Jul 2003
                    • 385
                    Well the « problem » came back!!
                    So I decided that, since my 5 years warranty ends in July, I will get it checked. So I brought it to my dealer last Friday…
                    He will get it to the Classé shop here in Lachine (Québec), and from there they will determine if the can repair or if they have to send it to Rotel’s HO in USA (Boston??)…
                    I’m in the wait for the call of my dealer…7-10 days if Classé can repair it and a month or more if it has to be sent to the Rotel HO for dome major repair!!!
                    Actually does anyone knows what are the (repairs) options ??
                    • thyname
                      Rotel RSX-1057. Should I purchase it?
                      by thyname
                      Myer-Emco here in N. VA have their private sale even soon, and I think I am ready to purchase 1057 in order to complete my HT system. I currently have:
                      Rotel RB-1080 Power Amp
                      Rotel RC-1070 Pre-Amp
                      Rotel RCD-1072 Cd player
                      Axiom M60ti speakers
                      Rel Q150E Sub...
                      15 January 2007, 19:04 Monday
                    • Kai
                      Rotel RSX-1560 will not power on
                      by Kai
                      I have a Rotel RSX-1560 that won't power on. I plug it in and turn on the master switch in back (and smile to myself as the light in the room flicker) and the unit appears to come on in standby mode (power light surrounding the soft button on the front is lit). But when I hit the power button on front...
                      28 June 2021, 10:28 Monday
                    • DNO
                      RSP-1069 Standby only, No FL display, no output
                      by DNO
                      This unit has been in service for quite a few years, but recently I've been turning it off via the rocker switch on the rear panel. Just yesterday, only the blue stanby light on the front lights up. The soft on/off switch will no longer turn on the display, nor do anything else. Nor does it respond...
                      09 August 2012, 00:11 Thursday
                    • rhjaisingh
                      Rotel RSP976 RSP-976 just died
                      by rhjaisingh
                      Hey all,
                      I have a Rotel RSP976, have had it for about 10 years, worked OK until last week, and this weekend wound't turn on. I have 0 technical knowledge about electronics, Rotel guys said they may not have parts even if I sent it in, but they will look at it for free. Some used units...
                      12 January 2015, 17:33 Monday
                    • Razvan
                      standby or power off?
                      by Razvan
                      I was wondering if you guys leave your RDC-7 on standby or you power it off? Is it better for the unit to be left on standby?
                      Razvan
                      17 February 2002, 03:09 Sunday
