standby or power off?
  • Razvan
    • Jan 2002
    • 115
    I was wondering if you guys leave your RDC-7 on standby or you power it off? Is it better for the unit to be left on standby?
    Razvan
  • Burke Strickland
    • Sep 2001
    • 3159
    Razvan -
    I leave mine in standby unless I am going away (out of town) for extended periods, or we are having hellacious electrical storms in the area (in which case I unplug everything as a safety precaution). Standby keeps critical circuits "warmed up" and "ready-to-go" without drawing a lot of power. Plus it is a heck of a lot more convenient, being remote controlled. :>)
    I'm not sure it is really "better" for the unit, but it can't be "worse" for the unit -- they went to a lot of trouble providing the "standby" mode as the default power-down mode via both remote and front panel control. And since "cold" power up is typically the moment that most electronic gear fails due to the initial internal surge of power through the circuits, standby mode means that the unit is seldom subjected to it.
    Burke
    • Kai
      Rotel RSX-1560 will not power on
      by Kai
      I have a Rotel RSX-1560 that won't power on. I plug it in and turn on the master switch in back (and smile to myself as the light in the room flicker) and the unit appears to come on in standby mode (power light surrounding the soft button on the front is lit). But when I hit the power button on front...
      28 June 2021, 10:28 Monday
      Cheap DIY balanced power device
      by ThomasW
      We've given alot of bandwidth to big $$, and even bigger $$$$ balanced power units. So I decided to create a budget (can't get any cheaper) DIY balanced power unit. This is one that even Andrew can afford, and that he can build ........... :wink:
      Start with a 8"X8"X4" indoor...
      24 June 2004, 00:33 Thursday
    • Glenn
      Power button, settings, RSX-1055
      by Glenn
      I have temporarily set-up my new RSX-1055 to make sure all is working correctly. It has the latest firmware.
      The current set-up is 2 channel. Just the basics for right now. I went into the set-up menu and changed the front main channels to "large". I set all the rest to "none"....
      26 September 2003, 14:54 Friday
    • johnvb
      RSX 1055 locked out on standby power
      by johnvb
      I've owned this receiver for about 1 1/2 years now, from day one the remote control/ ir strength has been really weak. I originally set the powering up of the unit with the "direct" mode, because of the POS remote response.
      I recently upgraded to a MX-500 universal remote. After...
      07 December 2004, 10:25 Tuesday
      Firmware update changes.
      by Andrew Pratt
      RSP 1098 Software Updates Release Notes
      V1.0.0 to V1.1.0 - Allowed a press of the function knob on front panel to power unit on from Standby. - Software relating to the MP3 decoding was changed. - Test Tone level reduced from -23dbfs to -30dbfs per Dolby spec. - Fixed lack of video output...
      22 February 2005, 15:07 Tuesday
