1066 problem
  • opus
    • 14
    1066 problem
    Please disregard, problem solved.
  • mitzipurr
    Rotel 1068 Sound Problem
    by mitzipurr
    Hi everybody
    I have just received the replacement for my 1066 a 1068 Processor. However when I switch it on the sound seems to fade in and out and I need to have the volume level at 60 and higher!!! To be quite frank my old 1066 blows it away at volume level 40 it is more than adequate......
    29 April 2005, 13:03 Friday
  • rd1bruce
    Rotel 1066 and subwoofer hum-please help
    by rd1bruce
    I have the 1066 and 1095 amp. When I connect my subwoofer(Martin Logan Descent) I get A noticable humm even with no signal being processed.What am I doing wrong? The sub offeres a few ways to be connected: 1.Left and right rca plugs
    2 LFE...
    03 March 2003, 15:11 Monday
  • greenjudas
    RSP 1066, RR1050 problem
    by greenjudas
    Hi everyone,I have had my RSP 1066 for 6mths or so,and yesterday decided to add a couple more functions from my dvd remote to the RR 1050.I have obviously upset it because now, I can't change to video 1[dvd] using remote.It will change and show dvd on remote screen but not on the 1066.To put it on video...
    30 January 2006, 22:20 Monday
  • Krzysztof W
    New 1066 bass problem?
    by Krzysztof W
    I love my 1066-1075 combo. The music is incredible, I am completely stunned.
    I have to add that I have Def Tech speakers (BP2006 mains-bipolar power towers, CLR2002-center and BP 1.2.x rear).
    I recently had upgraded software (version 1.44) and then I run into bass problem....
    26 September 2002, 11:57 Thursday
  • thedarklobster
    1066/1075 problem
    by thedarklobster
    Hello. I wanted to see if anyone had some advice for me with this issue. If I power up the 1066/1075 via the remote after it has been off for more than an hour I get a loud popping sound from all of my speakers. However, if I turn both units off with the power buttons on the unit themselves, I recieve...
    12 September 2003, 11:26 Friday
