Static Discharge and Volume on C2
  • MichiganMike
    • Mar 2004
    • 39
    In winter, I get an occasional spark from static when touching my audio stand or the equipment on it. This has the unexpected affect of changing the sound level on the C2, even if I do not touch it directly. If I switch inputs on the C2 with the remote the normal volume level returns. Has anyone else experienced this?
    Mike
  • Vince Helm
    • 134
    Hi Mike,
    Yes, sort of simular to your experience. I am now in the habit of touching a metal picture frame before I touch the C2 in order to discharge any static build up (during the winter). Always works for me. I also noticed that when I vacuum around the entertainment center and the C2 is on, a static can build up and cause a simular issue... so I do not use the C2 while using the vacuum. No big deal for me.
    Best wishes
    Vince
      Whoa, no, haven't heard that one either. Are you E.T.? changing channels by touching the TV box?
      • 5.0greg
        Crack/Pop when changing inputs...
        by 5.0greg
        I've been reading this forum for a few weeks now since I picked up a 1068 and the amount of info is great. I've been overwhelmed with the quality of sound and have had no problems with the unit minus one.
        Once the unit and amp are powered on and for instance it turns on in Video1, I then...
        10 May 2005, 09:07 Tuesday
      • NicholasT
        Getting static sound from right channel with Rotel RA1062/RCD1072
        by NicholasT
        I just purchased a Rotel RA-1062 integrated amp with the RCD-1072 CD player. I connected them to a pair of Pennaudio Rebel 2 speakers with Audioquest Type 4 speaker cable. I have all the components connected to a PS Audio Juice Bar outlet. I played a some CDs on the first day and it seemed to be...
        11 February 2007, 05:13 Sunday
      • mickyboy
        is parasound a23 simular sounding to 2205 please
        by mickyboy
        hallo all i have read reviews on parasound halo etc ,seems according to reviews that the new halo range ,differs slightly soundwise that halo is a bit more laidback than older range.
        i currently have a23 but it has had very little use approx 35 hours, judging from threads elseware that parasounds...
        05 June 2004, 11:36 Saturday
      • impulse
        Livingroom installation of ZA 5.2iw/5.3iw (or simular?)
        by impulse
        In short: new house - new possiblilities. Me and my family moved to a new house last year and now its about time to look into buliding a useable HT in the livingroom. While an ideal HT installation is preferrable, I need to make a lot of compromises. An ideal installation demands a lot space, and may...
        15 January 2012, 08:12 Sunday
      • Kevin_McC
        Static Electricity?
        by Kevin_McC
        I don't know about everyone else, but I've been experiencing alot of static shocks when ever I touch light switches, my equipment rack and even my gear.
        I realized yesterday that they must be pretty strong shocks because yesterday I got shocked by line voltage (don't ask) for the first...
        14 February 2003, 09:39 Friday
