I've had my rsx1056 for a cpl of years now and it just developed a problem.When watching direct tv the receiver will detect if it's dolby dig. like normal and the volume is fine,but when i get like a commercial which comes in as dpLll the volume drops dramatically,then when it goes back to dolby dig. the volume is back as normal.I've had this problem for a about 2-3 weeks now.Everytime this occurs i have to hit the DPLll on the remote to get the volume back.If 1 program i in dolby dig it's fine but as soon a DPLll program comes on the volume drops.Any idea what's happening?
slight problem with my rsx1056
Updated the firmware in the 1056 recently? Might have to do a factory reset.
Is it one certain channel or any Dolby Digital channel on Directv? If it's just on one or your local HD's through Direct, I would suspect something in their transmission.
You should be able to find some DVD's that have stereo PCM (PLII) in the menu and DD on the disc, see if it shows the same difference.
FWIW, it's usually the stereo track that's real loud compared to a DD track. Something that's inherent to the dynamic range DD has.
What firmware are you at just for reference? (hold down mute for 5 or so seconds).
Kevin D.- Bottom
by rick cI know i may have asked before but would really like to get some opinions to get me over the fence.I have an opportunity to get either a 7002 or 8002 for a significant price.7002 for 980. the 8002 for 1,400.So i may be selling my rotel.I have a tosh hd player that is connected via dig. because analogs...-
Channel: Club Rotel
by wettouWould you like to see these features implemented into the SSP-800
Dolby Volume, Dolby IIz and Dolby Headphone
http://www.dolby.com/professional/te...ter/index.html
Could someone create a poll to see the level of interest :B...-
Channel: Club Classé
by rick cThose that have the tosh.HD-a1 how do you have it connected for audio.Digital or analog.Reason i ask is i have a denon dvda/sacd connected to my rotel so the analog is used up.The tosh i'll be getting next week.Undecided on should i just connect the tosh digital or am i going to have to get a switcher(which...-
Channel: Club Rotel
by rick cI always thought that the rsx1056 should not be used with 4ohm speakers.Atleast that's what rotel told me a while back when i was inquiring about dynaudio speakers,so i ended up with B&W 603s3's/lcr600(really liked them anyway).Well i have upgraded my speakers to a System Audio setup(sa1750/sa720av/sa505's)these...-
Channel: Club Rotel
by rdb1276has anyone calibrated there RSP-1098 with the Digital Video Essentials dvd, for Dolby Dig. and DTS. What I have is that the DTS signal on the dvd is exactly 3 decibel's lower for the surround and surround back channels then in Dolby Digital-
Channel: Club Rotel
- Loading...
- No more items.
