Will RSX-1056 improve with a RB976 amp and does rsx1056 = rsp1066
  • mike.g
    • 3
    I have a RB976 6 channel amp
    It drives my M&K k17's and K4's all of which are rated at 4 ohm.
    The amp's specs are rated at 4 ohm and it is very clear the amp should and can drive 4 ohm speakers on all channels.
    I can get a s/h RSX-1056
    Considering my RB976 is about 6 years old, would the internal amplification of the RSX-1056 match or better the RB976.
    I am not worried about ultimate power figures, just nice sound quality.
    I have concerns whether the RSX-1056 can drive 4 ohm speakers. The specs say not, but the FAQ of the RSX-1055 say YES it can drive 4 ohm.
    The RSX-1056 is cheaper than a RSP-1066, which I originally planned. I assume used as a processor it should equal the 1066. Can anyone confirm this?
    Ideally I'm hoping I can sell my RB976 and use the RSX-1056's inbuilt amp and save even more money over buying the RSP-1066.
  • soundhound
    • Mar 2004
    • 816
    The RSX 1056 shares technology with the RSP-1068. I believe the RSX-1055 was the soul mate of the RSP-1066.
    The 1056 is quite capable. I use one for ht and it drives some unpredictable speaker impedances that are quite low, and does it with finesse.
    • mike.g
      • 3
      thank you.
      So would I get identical audio performance feeding an amp from an RSX-1056 used as a processor only compared to the true processor only RSP-1068?
      Do all those amps wired up inside the RSX-1056 effect the sonic performance compared to the processor only RSP-1068?
      • gianni
        • Nov 2002
        • 524
        In the more revealing sytems you may find the 1068 to be slightly better. That being said, many claim to hear litle or no difference with the 1056 used as a preamp. The amps on the 1056 are quite capable for a receiver. Sure separates have advantages but I doubt you'll hear any difference with the rb976.
        Fortunately for you, since you already have the 976, you can make a direct comparison. Also, go for the 1056 instead of the older 1066 as the new features would be worth having.
        • rick c
          rotel rsx1056 w/4 ohm speakers;misconception
          by rick c
          I always thought that the rsx1056 should not be used with 4ohm speakers.Atleast that's what rotel told me a while back when i was inquiring about dynaudio speakers,so i ended up with B&W 603s3's/lcr600(really liked them anyway).Well i have upgraded my speakers to a System Audio setup(sa1750/sa720av/sa505's)these...
          03 May 2007, 21:41 Thursday
        • GDEvans
          Wanted: RB976 Mk II manual
          by GDEvans
          I hope somebody can help me. I have recently purchased a second hand RB976 Mk II, but it came without a manual.
          I emailed Rotel and they sent me a pdf of the original manual (same as on their website) claiming it was the latest version.
          Is anybody out there kind enough...
          20 June 2007, 13:40 Wednesday
        • wywong
          RSP1066 Vs RSP1068
          by wywong
          I have an option of buying an RSP1066 or an RSP1068, the different in price is about $400. Can someone give me an opinion on whether it is worth the extra of $400 to get the RSP1068. I am currently using a Denon 3803 as a pre/processor and the RMB1075. Will this upgrade to the Rotel RSP1066...
          17 January 2005, 08:17 Monday
        • KrisKeen
          RSP1066 with SACD & Pioneer 989
          by KrisKeen
          hi Guys
          I purchased the Pioneer 989 avis universal player today and have some questions on connecting it to my rotel rsp1066/rmb1075 system
          Firstly, I know I need to get 6 Analog cables for my Multichannel output on the Pioneer 989 to the Multichannel inputs of the RSP....
          08 September 2006, 05:30 Friday
        • dcluley
          rb976 : rb956ax : Link inputs
          by dcluley
          On the rb976 one can link the inputs to all 3 stereo channels via a switch, yet on the rb956ax there is not that ability. If one were to make a 3 headed "Y" cable and plug the preamp out into all 3 channels on the rb956 - would that not act the same as the "switch"? Except opening...
          24 January 2005, 17:33 Monday
