RCD 991 laser fault? (HELP)
  • polik71
    • 3
    Hi , maybe I posted my question in the wrong place last time.
    Like some other Rotelians I started to have some bad problems reading CD-R and even CD with my RCD 991 (an used one...quite heavily and old item...but had at a very good price)
    Of course now I am in trouble :rofl:
    I disassembled the laser mechanism and found on the net some good infos about the Sony KSS213-B laser unit but not about any improvements of that unit or compatibility with the KSS213 family.
    This was my previous post and question in the RDC991 vs RCD991AE thread :
    Hi to everyone I have the same problem with my RCD991 , the laser seems faulted and the spin motor is a bit noisy. I found the Sony KSS-213B laser on the Net for about 15-20Euros (if asking to Sony local assistance center was 47Euros...). I think I will try to change it by myself.
    Do anyone knows about the laser calibration procedure on the KSS-213B trimmer?
    And what about the other KSS-213 family lasers? Is there any better quality/reliability compared to the B version? (compatibility issues?)
    Thanks in advance for the interest
    Marco
  • Kevin D
    • 4601
    Very few of us here have taken things to that level. It might be a while before someone comes in that knows an answer.
    Good luck!
    Kevin D.
    • Taito
      • 226
      It could be that the laser was/is ok and that the motor which moves the laser is worn out (The symptom would be frequent skipping). I've come across that before on an RCD-855. If that is the case, a Rotel service centre should be able to fit a new motor for somewhere around $100. You could try that.
      Good luck, Ben.
      • polik71
        • 3
        Thanks Ben , infact I also ordered some days ago the 2 motors (spin+sled motors) for a better and complete replacement. Anyway ,apart the motors that doesn't need any calibration , the new laser I think needs it. I was reading time ago that the current flowing in it can heavily affect the real life before failure.
        • shane2468
          Rotel RCD-991 Vs RCD-1070
          by shane2468
          Just out of curiosity, has anyone here compared the Rotel RCD-991 CD player to the Rotel RCD-1070?
          Kind Regards.
          11 August 2010, 08:14 Wednesday
        • lastexit
          Should Rotel make another statement CD player similar to the old RCD-991?
          by lastexit
          Is there any chance of a definitive "statement" single chassis CD player in the pipeline from Rotel? I'm not harping on the RCD-1572 but I can't help how awesome it would be if Rotel come out with a beefier, heavier, and much more "cost no object" type player similar to the old 991....
          20 December 2018, 11:00 Thursday
        • Tha Freak
          Just bought a used RCD-991...
          by Tha Freak
          Hi I just concluded a deal on a used RCD-991...I will have it on Friday!!
          is is a good CD player? (I know it's good, since I owned few Rotel products and herd few CD players too...but nevet a flagship!)
          Any comments?
          It will be paired with a RA972 (also used)...
          11 April 2005, 22:37 Monday
        • Tha Freak
          DM303/ASW300 for Rotel RA-972 & RCD-991 ??
          by Tha Freak
          I currently have a Rotel RA-972 integrated amp and a RCD-991 CD player…
          I need speakers for that little combo to listen some music in dinning/living room (separate HT is in the basement)…
          I was thinking at a B&W DM303/ASW300 sub-sat combo for that set up…
          17 January 2006, 15:54 Tuesday
        • Tha Freak
          by Tha Freak
          (originally posted in the B&W speakers club, but since no interest in my post...)
          I need speakers for that little combo to listen some music in dinning/living room (separate HT is in the basement)…...
          19 January 2006, 09:15 Thursday
