I just replaced my TA9000ES with an RSP 1068. I have a Toshiba DST3000 Sat Recvr that I am trying to hook up to the Rotel using compoenent video. When I do, I get no video and on my Sony LCD projector, it says check input A (this is the compoenent in where my Rotel is connected. If I hook the Toshiba directly to the LCD projector it displays fine. If I hook up my Toshiba to the 1068 using S-video, the 1086 upconverts it and outputs it to the LCD using compoenent video. Does anyone have an idea what I'm doing wrong? Thanks in advance.
RSP 1068 Problem?
eric, make sure that you connect the first component input with the VID 1 on the front panel the second to VID2 and the third to VID 3, also make sure the the colors are matched up correctly it is easy to put the blue into the green .... good luck
Get the most BANG for your BUCKGet the most BANG for your BUCK- Bottom
by hired goonG'day,
After a long saga trying out an RSP-1068, then an RSP-1066, I finally settled on the RSP-1068 yesterday. I think (hope!) I've made the right choice.
Anyway, I've got a couple of questions, which I trust someone here can help answer.
(1) I've got an...-
Channel: Club Rotel
by OpocHello all, I just purchased my first Componet HT setup, 1068 and 1075 and I'm experiancing some issues.
I am using a Comcast Motorola 6208 STB, Kenwood DV-502 DVD player (not progressive), and a Mits 65809 (owner's manual ). The Cable box and the DVD player are connect to the 1068...-
Channel: Club Rotel
by eelco74Hi all,
I had an oppertunity to upgrade my rsp-1068 to a rsp-1098.
I have all sources (xbox 360, Denon dvd-2900, satbox and popcornhour) component connected to the RSP and then to the beamer/plasma.
In order to use the tft screen on the front, I also connected...-
Channel: Club Rotel
by Bing FungI was looking at the specifications of the 1068.
Is that Group Delay the same as Audio Delay to sync the Video and Audio together?
If so, what is the range of adjustment? (i.e. milliseconds)...-
Channel: Club Rotel
by tennbergHi everyone,
Is there a way on the remote that comes with the RSP-1068 pre-amp/processor to get the display to say "Video 1" when you press "Vid 1"? Right now, the default is "DVD" for Rotel DVD players. However, I'd like to change it to say "Video 1."...-
Channel: Club Rotel
- Loading...
- No more items.
