Subwoofer - MAX Setting
  • Adz
    • Jan 2004
    • 549
    Question
    I understand that when you set the Max setting on the subwoofer set-up menu, it basically sends a double bass signal - one to all speakers set to large and an identical bass signal to the subwoofer. This essentially doubles up on the bass being produced. I assume this might be worthwhile for some movies but I was wondering if anyone has tried this and what they thought?
    Adz
    Adz
  • jimmyp58
    • 1449
    I have mine set up this way and it produces an incredible sound regardless of 2 CH PCM (music), multi-channel audio, or movies. Of course you'll have to do some configuring but once you have found the sweet spot, it is incredible.
    jpiscitello@ameritech.net
      Twin Moderator Emeritus
      • 16706
      While audiophile's may scoff as you're messing with the purity of the signal by adding additional information (bass). I say, if you enjoy it, (you bass fiend you ) then knock yourself out.
      Personally I prefer mine straight up audiophile-style but I also have pretty bass-capable speakers and I get enough bass overkill in my car.. hee hee 8)
      Need a new display? Questions about new display technologies? Visit RPTVs, plasmas, and other monitors @ HTguide
      • jimmyp58
        • 1449
        I guess that is what makes the world go 'round and why they have adjustment settings....
        By the way, I do not have bass overkill. Its just that I found this setting suits my system best. I do not enjoy blastin' ghetto bass in my house nor my car. I have a pair of Def Tech BP7000SCs for my fronts; they have a built-in powered sub so they are more than capable of producing a dynamic bass response. Combine that with the external subs I have and perform the right adjustments to the sub and speaker settings and the sound reproduction is unbelievable.
        • Bam!
          • Jan 2004
          • 2458
          Jimmyp58!
          Question...since you have multiple subs in your room...how did you go about placing them...also enabling them not to cancel eachother out....
          I am curious since I will be doing multiple subs in the next couple of weeks...
          Thanks!
          (Jason I relaize after typing this that this may put this thread slightly off topic...So what should I do to ask him this question?)
          Thanks duders!
          Bam!
          Got a nice rack to show me ?
          • jimmyp58
            • 1449
            I sent you an e-mail.
            • Bam!
              • Jan 2004
              • 2458
              Jim!
              Thnaks you rule!
              Bam!
                • 16706
                Bam, as long as that last post is where it ends then I won't have to :smackbutt: you. :evil:
                • jimmyp58
                  • 1449
                  You are certainly welcome....
                  • mule.variant
                    • Mar 2004
                    • 8
                    I am doing this right now as well. I've crossed my sub at 40 to fill in the bottom octave where my N804s are a little weak. I'm mostly avoiding any doubling, as far as I can tell.
                    • Bam!
                      • Jan 2004
                      • 2458
                      Jason!
                      don' t you worry there bud everything is under control a rooney
                      ...Filling the sub in at around 40 hz....it's awesome....no question.
                      Wooo whoooooo!
                      Bam!
                      • greenhorn
                        Basic Bass \ Sub-Woofer Setting
                        by greenhorn
                        Looking for some knowledgable help with appropriate basic Bass \ Sub-Woofer Setting. Tied up here with far to many possible setting for me to get a handle on. Couple of the pieces of my equipment are Bass \ Subwoofer adjustable so I'm looking for what is general correct baseline setup.
                        12 April 2007, 22:22 Thursday
                      • bleeding ears
                        1068 Subwoofer settings
                        by bleeding ears
                        When setting the subwoofer levels for each mode, eg Dolby digital, stereo etc, I always find that I have to set the DTS level much lower than all the others.
                        EG DTS is - 9 on the menu
                        Dolby Digital 0
                        Stereo 0
                        Any ideas why this is ?
                        DTS can...
                        13 January 2009, 09:01 Tuesday
                      • maxwebster
                        rsp-1570 Advanced Subwoofer settings
                        by maxwebster
                        Hello fellow tweakers,
                        I have two questions regarding bass management with the 1570:
                        1) What is the purpose of the advanced speaker settings for the subwoofer? I am using advanced settings for all my speakers but have left the subwoofer setting at 80Hz because I have no...
                        06 April 2009, 11:17 Monday
                      • BlueSander
                        How to get passive subwoofer to work with RSX-1067?
                        by BlueSander
                        okay, so i ended up with a new rsx-1067. The sound is great (i kinds want to go seperate now but prob not for awhile now). The current problem now is I'm running a stereo with a passive subwoofer. I connect the passive woofer to left and right font, then connect the front speakers from that woofer....
                        05 December 2009, 03:24 Saturday
                      • stone24
                        How do I determine max volume on my rotels?
                        by stone24
                        I have the RSP1570 pre-amp and three RB-1582 amps powering my home theater (Paradigm Monitor 11 speakers). I had an RMB-1575 prior to the 1582s. I was not very happy with the 1575 since I had popped two amps and blown the center channel once. I was convinced that the 1575 did not have sufficient current...
                        12 October 2011, 11:00 Wednesday
