REMOTE CONTROL IR CODES FOR 1098 RR-1050
  • MICHAEL STRO
    • Oct 2003
    • 100
    are there ir codes to put in this remote to operate a (denon 2200,sony tv,etc) or do i have to input one at a timefor every remote.
  • Aussie Geoff
    • Oct 2003
    • 1914
    Michael,
    The RR-1050 Remote only has built in IR codes for Rotel equipment. You need to learn (using the original remote) the extra IR codes you need to the keys you want. Remember for each different device you select (by a long press of the device key) ALL the main keys on the remote except volume etc are now associated with the new device and can be learned. It takes some time (5 minutes per device) but is worth it.
    Geoff Costello
