SoundGraph(iMON.soundgraph.com) has announced very innovative product called "iMON" for HTPC (Home Theater PC).
iMON is the USB remote controlling device by IR (Infra Red) signal to control your PC wirelessly. You might know there were several remote controlling devices in the PC market, but our iMON is basically different from those products and has many special features and excellent user interfacing points. So I would like to introduce our new product iMON to you.
Our iMON is composed of USB connection H/W receiver (iMON Station), it's Remote Stick Controller (RSC) and nice S/W (iMON Manager). It can control every Windows applications with just one remote controller. Also, our iMON can recognize the foreground application and automatically generate the right keyboard shortcut to active Windows application, so user can use the same play button of the remote controller in order to control the 'WinAmp" as well as "Windows Media Player".
Please refer features of iMON below and visit our Website http://iMON.Soundgraph.com and then you will be able to compare our product with another product.If you have any question on this matter , please do not hesitate to contact us.
Features
1. Perfect Control of popular music, DVD, Movie Players using a remote controller
2. Powerful Mouse Functions of moving mouse cursor as smooth and precise as real mouse
3. Stylish Cool Design of iMON Station according to the variable computer situations
4. Convenient Setup and Use of iMON RSC(or iMON RC) through automatic setup wizard of the application hot-key setting
5. Maximize of the remote controller button use by generating different hot-keys with the same remote controller button under different applications.
6. "Application Launcher" for the immediate load of the application
7. "Task Switcher" for the switching in the loaded applications
8. "Monitor Resolution Changer" for immediate monitor resolution changing by remote controller.
9. "All-time Control Window" for control of one application regardless of the current active state.
10. MACRO for setting and execution of the complicated command like Log In, Composition work of mouse and keyboard, and so on
11. Additional convenient functions like PC Power OFF, Screen Saver Activation, Sleep, Alarm and so on
12. Wireless Controlling of PowerPoint Presentation using a remote controller
13. Excellent IR signal receiving sensitivity up to 15 meter distance and 45° angle in any direction
14. Use of ANY general House Appliance Remote Controller with iMON through the remote
controller registration and setup wizard
15. Automatic Search and Setup Functions of popular multimedia S/W
16. On Screen Display of volumes, timer info, etc for convenience control of PC
17. More Multimedia Applications can be registered and set by the user custom setting
Features
