IR Keyboard + Harmony Remote - Can it work?
    • 1933
    My Streamzap + Girder combo doesn't work with Windows 7. Streamzap works... Girder doesn't.
    So... I was wondering if I buy an IR wireless keyboard, use the shortcut keys that I need (i.e. L for subtitles, P for play), should I be able to program Harmony to learn those particular IR codes manually? Then I would only need the IR receiver, and not the keyboard at all since the remote has learned the keys I need. Anyone using something like this?
