Has anyone figured out how to turn on your components without messing up the device/input buttons? I was able to get a device to turn on after programming it, but then the receiver would not change to the correct imput. How are you suppose to use the macro buttoms if you cannot program your devices to turn on using this remote? It seems like the directions would lead me to believe that this can be done. To clarify: I want to turn on my dvd player with rotel remote and tune my rotel receiver to video 1, am I able to do both of these by holding down the v1 device/imput button?
Another weird thing is I tried to program the power button that is underneath the slide down cover, and instead of turning on/off the device I programmed, it would turn off the receiver.
Thanks for any help,
-Jeff
-Jeff
