1098 Bass Management: Please HELP
  • Locutus2k
    • 62
    I know that there are many threads on this argument, but please i need a CLEAR response to one question:
    I would like to have a FULL RANGE front speakers with the ADDICTION of a subwoofer bass-redirection. this on the digital and\or analog stereo inputs of the 1098.
    This means that switching sub on\off will only affect lower frequencies impact, but NOT the sound quality and\or the audio spectrum of the L\R. Is this possible? I mean: if i set main speakers to small i DO have sub redirection, but withouth sub the sound is very poor and i don't want this.
    1098 has the latest firmware, speakers are Klipsch RF-7 and sub Velodyne DD18. I know and understand the diff'rences beetween STEREO and BYPASS mode.
    Thanks in advance for any help,
    Luigi
    You're wanting something that can't happen... I think.
    If you set your speakers to Large for stereo listening then all bass is sent to your L/R. Now if you have them set to large, then no bass will be redirected to the subwoofer (except for LFE stuff). So you have to set the speakers to small for stereo/2-ch listening. Which effects the bass going to your L/R speakers. You could try settin the crossover as low as it will go and then see what happens when you turn the sub off.
    By-pass or course means the processor does nothing to the audio source and you can not redirect the bass to the sub.
    So you've got either Large/no sub or Small/sub.
    • Locutus2k
      • 62
      I've discovered that in the advanced speaker menu if i set ex. Stereo/Music on MASTER instead of small or large, than the low frequencies are directed to both front speakers and sub. Is this normal? What is the MASTER settings on the advanced speaker menu? I mean: what does it do exactly? :roll:
      Luigi
        That just means that it will use the "master setting."
        So if you have the master setting for Stereo/Music set to small, it will use that...that way if you change the master, it will change as well.
        Maybe that's how I did it before, because I bet your Master is set to Large, plus to use the subwoofer. Too me that created too much bass (in essence doubling the frequencies that both the L/R and Sub can play).
        But that might be the only way you can do that...
        • Aussie Geoff
          • Oct 2003
          • 1914
          Luigi,
          I believe the RSP-1098 can do what you want. If you look at page 33 of the manual under the section titled Subwoofer which states
          SUBWOOFER (yes/no/max): The YES setting is the standard setting if your system has a subwoofer. If your system does not have a subwoofer, select NO. Select the MAX setting for maximum bass output with normal bass being duplicated by both the subwoofer and any LARGE speakers in the system.
          Essentially the MAX seeting seems to do what you want... (If I understand your requirment) You can even toggle this on or off using the remote control in a few keystrokes.
          Geoff
            That's what I was thinking of, thanks Geoff!
            That's what I was thinking of and couldn't figure out while fiddling this morning before work.
            • Locutus2k
              • 62
              Originally posted by Aussie Geoff
              Luigi,
              ... which statesEssentially the MAX seeting seems to do what you want... (If I understand your requirment) You can even toggle this on or off using the remote control in a few keystrokes.
              Geoff
              OK, that's working, but ONLY if the single listening mode (DD, DTS, STEREO, MUSIC) on the advanced spekaer menu is set to MASTER and the front speakers on the standard menu are set to Large.
              So far, i'm satisfied. Thanks,
              Luigi
              • Club1820
                Sub Setttings - Lack of Bass
                by Club1820
                Hello. I have a couple of questions regarding the settings for the sub on the 1068 pre/pro.
                I currently have my M&K VX-860 250 watt sub volume level set at Reference and also set to bypass its crossover settings in favor of the pre/pro. On the 1068 I have the crossover set...
                25 January 2007, 16:09 Thursday
              • Aussie Geoff
                RSP 1098 Wish List V2.0
                by Aussie Geoff
              • whmacs
                RSP-1098 Bass Calibration Observations
                by whmacs
                Hi All,
                More of an observation than anything else, but I recently recalibrating my subwoofer using Digital Video Essentials. This disk has a 75db output level. So as usual I set the front left speaker to output 75db (77 on RSP-1098) with the speaker level set to 0db. I then cut over to the sub...
                24 March 2004, 15:34 Wednesday
              • Sithlord10
                1098 Bass Managment Settings
                by Sithlord10
                I have a question regarding the Multi-inputs settings particulary the LFE Direct option on the 1098. I've read the manual but I fail to understand it's meaning. Under the Sub setting I've put the level to max(10db) under Multi-Input but when I play a SACD and press the sub button on the remote it displays...
                12 September 2003, 21:02 Friday
              • rockbobmel
                Can I get bass and Sub together?? RSP-1098
                by rockbobmel
                I can't figure out the bass management to get both 100% bass to the fronts plus a strong signal to the sub.
                I had to Y the FL & FR so the signal splits to the Velodyne ULD controller.
                Any suggestions.?? Thanks.
                01 December 2005, 23:10 Thursday
