RCD-951 intermittent tray problems
  • Feisal K
    • Aug 2005
    • 28
    sometimes I put a disc in and it reads it immediately, other times it just spits it back out and only takes it after a few presses on the remote or opn/cls button on the unit.
    has anyone come across the same problem? what could be the matter, and would it take a quick fix or a replacement part?
    thanks
  • Kevin D
    • 4601
    Could possibly use a good cleaning of the laser unit. I have no direct experience and due to the age of the unit you may not get immediate response.
    Here's a bump back to the top for you.
    Kevin D.
    • gianni
      • Nov 2002
      • 524
      I have one of Denon's older upper line units that started doing the same thing.
      I took the top off and cleaned it up and the problem disappeared.
      • Feisal K
        • Aug 2005
        • 28
        thanks guys
        I'll give it a clean up :T
